Speaker Cuts in and out.
Old Jun 20, 2009 | 11:10 PM
GQWeApOnX's Avatar
So I currently have
1.ecplise AVN726E
2.Schosche FAI-3A
3.stock speakers.
4.Stock Bose amp
5.JDM AC Controller & Dash
The issue is that on my front passanger side speakers has no sound, but when I crank up the volume to really high the sound comes back on.
Also when the sound is on low volume then it gets cut off, but when i hit the side of the dash the sound comes back. it also does the samething when I hit bumps.
When I play the music at high volume i have no issue with the sound cutting off.
This is annoying me and I been searching on the fourms to find out what the problem is. Please help.
Old Jun 23, 2009 | 09:18 PM
GQWeApOnX's Avatar
bump. Help me plz =(
Old Jun 23, 2009 | 10:15 PM
TroysG's Avatar
sounds like a short. was it professionally installed? if so take it back most places offer a guarantee on the install. if you did it yourself. take it all apart, look for the grey and grey back wires - or the grey rcas. make sure they are not stripped back, crimped or damaged in anyway.
Best this to do would be try to replicate the issue. and from there you can find out if it's a short being caused by a crimp/wire damage or if it's an issue with the amp or head unit.
Last edited by TroysG; Jun 23, 2009 at 10:15 PM. Reason: wireless keyboard is dying
Old Feb 25, 2010 | 12:05 PM
Deezflip's Avatar
lil reviving bump...
I have this issue too, I'm thinking it might be corrosion or a short in the stock speaker wires. Seems like other people have this issue regardless if they have an aftermarket or stock radio, amp, and/or speakers. I might try running new speaker wires all around when the weather is good.
Old Feb 26, 2010 | 11:20 PM
liukai's Avatar
i have a very similar set up and same exact issue, seems to be pretty common. LOoks like we'll be doing some trouble shooting, and hopefully somebody finds a solution!
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
