G35 coupe rear deck cannot handle subwoofers
Old Jun 18, 2013 | 10:23 PM
TotalChump's Avatar
So I just installed one of the JBL GTO 938 speakers in the rear deck and, like you all said, the bass is really weak. Almost non-existant. I instantly came inside and looked up links some of you gave me http://www.woofersetc.com/p-10394-cl...ubwoofers.aspx and I was thinking about ordering those woofers. But after reading bsowhats and wrathernauts comments regarding the lack of power from the stock amp it may not even be worth it. I guess the only good thing is that I bet the deck woudnt rattle tho with these woofers alongside the stock amp considering the lack of power coming from the amp. I think I got to suck it up and just finish this project up. Maybe I will just listen to talk radio and sports.
Old Jun 18, 2013 | 11:04 PM
eggyhustles's Avatar
dont put those in the rear deck
Put subs on a baffle, behind the seat
Old Jun 18, 2013 | 11:11 PM
TotalChump's Avatar
Dammn eggyhustles that is pretty pumped. Unfortunately, I won't be able to totally Bassify my car like that tho. So those CL-69SUB/CF 6x9's wont really give me much more thump than the JBL 938's considering I would be using the stock amp for both?
Old Jun 18, 2013 | 11:17 PM
Nope.
They'll be a complete waste of money.
Old Jun 19, 2013 | 02:18 PM
evil-G-nius's Avatar
Eggy...are those 10"s or 12"s? I have a set of Diamond Audio subs that are waiting for a car. I have been wondering if the coupe trunk can take 2 12"s and still have room for bags. Your setup makes me very optomistic
Old Jun 19, 2013 | 02:23 PM
10s
As long as u can make the subs fit behind the seat, you're good.
Old Jun 19, 2013 | 02:39 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Using the stock amp for anything is a waste of time.
Old Jun 19, 2013 | 05:14 PM
maybe one 12 will work. Unless someone has pic proof that 2 12"s can be mounted like Eggy's
Old Jun 19, 2013 | 05:17 PM
Try em
Might be a tight fit
whats the model # of the subs?
A lot of subs won't work well infinite baffle.
Old Jun 20, 2013 | 02:05 AM
I gotta go dig em up...they are Diamond Audio 12's DVC's if I am not mistaken
Old Jun 20, 2013 | 09:00 AM
dvc=dual voice coil
Need model #
Old Jun 20, 2013 | 01:00 PM
^^^I know. LOL. I was just sayin
Model is D9
Old Jun 20, 2013 | 01:07 PM
Yes those can work
SPL - 86.5
Qms - 3.5
Qes - .60
Qts - .51
Fs - 33Hz
Vas - 22L
Bl - 21
Xmax - 24mm
Highish efficiency
lots of xmax
highish QTS
Those would be pretty good in IB
Old Jun 20, 2013 | 01:25 PM
Ib?
Old Jun 20, 2013 | 01:35 PM
  #30
It's called infinite baffle.
