Metra 7551 and F90bt questions
Old Aug 11, 2009 | 10:32 AM
Manual G's Avatar
Originally Posted by bina12834
duh!!! wow....i dont know why i thought car audio RCA's were any different than any other RCA's....wow....now im embarassed.
why would metra not just make their plugs red and white, since RCA plugs are standard red/white everywhere else?
That's a good question..I'm not sure.
Old Aug 11, 2009 | 10:33 AM
bina12834's Avatar
Originally Posted by Manual G
Are you doing the hardware bypass on your F90bt?
of course....its done already....i did all the wiring i could outside of the car to make it easier when i go to install.
Old Aug 11, 2009 | 10:35 AM
Manual G's Avatar
Great! Glad I could help.
Old Aug 11, 2009 | 10:36 AM
bina12834's Avatar
yea all ill need to do when i go to install is plug in all the harnesses and plugs and tap a few wires, and ill be good.
Old Aug 11, 2009 | 10:21 PM
PeterUbers's Avatar
looks like you have all your questions answered
Old Aug 15, 2009 | 07:22 AM
jin22gt's Avatar
Did you finish your install?
Hows the sound with the 7551 harness? I had the 7551 harness hooked up to my f90bt and the sound was way to low. I had to switch it with the 7550 but now I have static/buzz sound.
Old Aug 15, 2009 | 11:49 AM
TroysG's Avatar
reason why Metra uses the colours they do is because those colours are the standard throughout car audio. Installers know this better than they know their g/fs birthday.
Also if you look at the wiring harness on the pioneer you will see 2 white, 2 grey, 2 purple, 2 green, each pair with a black stripe. they are very similiar to the metra colours don't you think - they are the speaker wire colours
Old Aug 16, 2009 | 11:41 PM
bina12834's Avatar
yea....i got that
Old Aug 18, 2009 | 12:04 PM
blklude98's Avatar
Would like an answer to this question because I'm going to be doing the same.
Thanks!
Old Aug 18, 2009 | 02:10 PM
TroysG's Avatar
hey guys... so that you know... it comes down to the preout voltage and the tuning of the EQ from the deck. Coming directly from the deck using factory speakers, you will likely get better sound out of the 7550 harness.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
