best route for speaker wires?
Old Nov 30, 2009 | 04:16 AM
RADRaze2KX's Avatar
Question best route for speaker wires?
Hey guys, quick question:
routed RCA's from a new factory in-dash stereo to the trunk for a 4-ch amp (fronts/rears) and 2-ch amp (2-sub)... Get some alternator whine when it's cold out. what's the BEST route to avoid this from happening? I pulled my seats and routed along the driver's side near the doors (which is horrid as is, factory power wires for lights and speakers all over the place).
I'll be upgrading the grounding for the engine first, of course.
Old Nov 30, 2009 | 09:09 AM
blazeplacid's Avatar
what head unit do you have? Some have issues with rca noise
the "dont run your power wire and signal wires on the same side" is a myth.
Your getting ground noise from somewhere, where is your ground located?
Old Dec 1, 2009 | 02:35 PM
TroysG's Avatar
are the power wires ran on the opposite side as the rcas. if you have tin foil what you can do is wrap the RCAs in that - adds additional shielding.
also how high are the gains on the amp set?
Old Dec 22, 2009 | 03:07 AM
RADRaze2KX's Avatar
I'm in the process of redoing my speakers (blew all 4 stock speakers... yay me)... I'll redo all the wiring christmas eve and see if the wine goes away... I need speaker adapters for 6.5's with large baskets... any ideas?
Old Dec 22, 2009 | 08:43 AM
you can trace the factory speaker and its plastic housing
then drill out holes that will match your factory adapter
then cutout whatever size you need
Have you tried a new grounding spot??
The rca next to the power wire is not your problem, im runing my rca cables for my sub and fronts right next to 2 4ga wires
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
