Wire Gauge???
Old Dec 10, 2009 | 12:16 AM
Cueball369's Avatar
Wire Gauge???
So i have two 12" kicker l7 with a 1350 RMS amp. There combined impendence is 2 ohms. What gauge wire should I run to the battery??
Thanks
Old Dec 10, 2009 | 10:28 AM
liche's Avatar
first thing you should do before worrying about wire gauge is getting a new high output alternator.
Old Dec 10, 2009 | 11:22 AM
Cueball369's Avatar
So how much would a high output alt cost installed? and who would you recommenced that i get one from?
Old Dec 10, 2009 | 02:20 PM
liche's Avatar
Come on man. Read the rules. Do your own homework. No one wants to do the work and research for you.
Search the forum - there is a plethora of information available and GOOGLE as well.
Old Dec 11, 2009 | 10:44 AM
MidnightG35X's Avatar
1/0 is the wire gauge you need. A new alternator is probably not necessary if you are just listening to music daily. If you plan to compete playing test tones all day, yes, you need a new alternator.
Old Dec 11, 2009 | 10:49 AM
blazeplacid's Avatar
no need for a high output alt
im running a nine.1(1400rms/120amps) and a alpine 4 chan amp (300rms/30amps)
no dimming
run a good ground and you will have no issues
more then likely you will be fine with 4ga. 4ga can handle up to 130amps
0ga more than 300amps.
Old Dec 11, 2009 | 11:07 AM
Cueball369's Avatar
thanks guys.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
