2005 g35 coupe - bluetooth and iphone
Old Feb 17, 2010 | 06:56 PM
nevian's Avatar
does anyone know if there is an aftermarket bluettooth device that i can add to my existing g35 sound system to work with iphone's bluettooth to play my iphone music?
thanks
nevian
Old Feb 17, 2010 | 08:05 PM
Silencer_0's Avatar
I think the only way to stream music from your iphone through bluetooth is to buy a new headunit.... I can't imagine the sound quality being too good if there is a bluetooth accessory that can stream music to add onto the stock stereo.
Old Feb 17, 2010 | 08:12 PM
Grownmansexy35's Avatar
iphone
THERES AN ADAPTER KIT i will get the name of it tomorrow. im having it installed in my factor radio. its ran off of radio stations thru FM. its 250.00
Old Feb 17, 2010 | 08:23 PM
Silencer_0's Avatar
$250 for a kit that will transmit the music through radio stations? Sorry dude, but any type of FM transmitter sounds bad, will have static, and will be annoying to have to find the "optimal" station everytime you go somewhere. You're better off with a module that will give you an AUX and iPod/iPhone connection.
Old Feb 21, 2010 | 10:32 PM
05m6coupe's Avatar
Parrot 9200 < http://www.parrot.com/usa/products/b...-free-car-kits > best one that i have seen it works great, have it in my 05 coupe little pricey but worth it the harness for your car is 200 bucks and the unit is 300 bucks depending where you buy it.
Old Sep 5, 2010 | 01:19 AM
Bolaris's Avatar
Scrap my post! Definitely doesn't apply for stock ride.
Old Sep 5, 2010 | 03:19 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by Bolaris
Stay clear of anything transmitted wirelessly for streaming. Go copper or don't waste your money.
Best way to go is tap into your tvr aux input from the tuner in your trunk. Then once you've got leads coming out from there you can do any setup you need. Not only will you get a clean low noise insulated line to your head unit, you'll also get video.
You can run leads to your armrest for your iPhone or connect a carputer, a tv tuner, or a media player in the boot with an ir remote through to the dash.
At the moment I throw my iPad into the trunk in the mornings with my entire music collection and use my iPhone in the front to control it.
Way to respond to a 7-month old post with some irrelevant post.
tvr aux input? VIDEO in a stock G35 coupe?
Old Sep 21, 2010 | 09:42 PM
C.R. Hustlewell's Avatar
@ Nevian
I was at the audio shop today and they told me about a device by Got2b wireless. The product is g2-2200. Im still researching it but it. You should check it out let me know what you think.
laksjd84
Feb 28, 2026 01:58 PM
mike730
Jan 12, 2018 04:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
