speaker trouble shooting question. . .
Old Feb 25, 2010 | 12:52 AM
liukai's Avatar
i've been searching on threads about issues with the BOSE speakers going out, or 'in and out'. . .perhaps if you it a bump it somehow works all of a sudden, and most of the response are that the HU is the issue, or curcuit board, etc. . .
MY problem: i have an aftermarket double DIN set up with a Eclipse AVN 5435 unit. . .all my speakers are stock BOSE. . .now about 3 years later. . .my driver's side front speaker goes in and out. .sometimes it works, sometimes not. . .if it doesn't work, the simple remedy for me is to increase the volume to very loud, and than suddenly it works again, and i would lower the volume and it'll still work. . .again, sometimes it'll work for a hwile, than randomly go out again. . .and than once again, i woudl increase the volume to get it going. . .
i don't think its a serious problem. . likely a loose connection? not an issue with the my Eclipse unit? any thoughts? thanks
Old Feb 25, 2010 | 01:56 AM
S 854's Avatar
Sounds like a loose connection. When you installed the HU, did you use a Nissan wiring harness or did you splice into the wires? I spliced, wound up having intermittent sound every now and then and had to go back in to fix it.
I'm not a big fan of the stock speakers, Bose or not.
Why not just upgrade to a decent component set? They can be had for less than $100 and whatever you buy to replace the Bose would be a vast upgrade to the puny OEM tweets/mids. I'll post up a pic if I can find one when I removed my Bose set so you can see how physically crappy they are.
Old Feb 25, 2010 | 03:42 AM
driftGT350's Avatar
I have this problem lol.
Old Feb 25, 2010 | 10:02 AM
blazeplacid's Avatar
if you can pin point it to the mid or the tweet only, then you probably have a loose connection or the tinsel lead is acting up
does the tweet go out, mid only, or both?
this might be a good time to swap out the bose stuff
Old Feb 25, 2010 | 11:22 PM
liukai's Avatar
Thanks for the responses. i used a aftermarket harness. i need to further investigate whether its the tweet or mid, or both, and will recheck the connections. But yes, it does seem like perfect timing to swap out the OEM Bose speakers. . .though i already promised myself no more MODS this this year. . .promises are made to be broken.
Old Feb 26, 2010 | 05:17 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
You didn't mention that it was replaced, so I'm going to say it's the Bose amplifier going out. It uses a volume-level-based EQ, so when you crank it up loud enough, it's switching over and able to get that channel's circuits going enough that they stay on when you lower the volume again.
Old Feb 27, 2010 | 09:16 AM
driftGT350's Avatar
I hope you're right wrathernaut... I don't want to take my car to a audio place and get ripped a new a**hole. My fronts are doing the same, and I just realized my rear speakers are out as well.
Old Feb 27, 2010 | 10:05 AM
You've only got things to gain (except money) by doing RCAs straight from the headunit to the aftermarket amp, since the Bose sucks.
I'm pretty sure there's a few guys in SoCal who can help you with an amplifier install, so you don't get ripped on install fees. Try hitting up the regional forum.
Old Feb 27, 2010 | 06:18 PM
liukai's Avatar
if i were to upgrade the amp, i'm assuming keeping teh stock speakers would be ok?
Old Feb 27, 2010 | 07:00 PM
S 854's Avatar
^ It would work, not sure if it would be ok
I'd imagine upgrading your amp only would magnify the epic crappiness of the stock speakers. You can replace the front speakers while you're at it and the sound quality would vastly be improved over the Bose amp/speakers.
I used to get Crutchfield catalogs in the mail, and they always struck me with their comparisons of 'stock vs. aftermarket speakers'.
Stock Speakers vs. Aftermarket Speakers
Replacing the Bose amp/speakers at the same time would take less time/resources than doing one at a time. You'll save some money and your ears.
Old Feb 27, 2010 | 07:14 PM
liukai's Avatar
Thanks. . .i'm actually in the process of researching a whole new set up. . .new amp, speakers, and likely sub
Picture Share
Feb 4, 2018 12:41 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
dseet
Oct 11, 2015 12:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
