For those looking at Z110BT (Coupe)
Old Mar 8, 2010 | 02:53 PM
Eno's Avatar
Eno
Exclamation For those looking at Z110BT (Coupe)
Eh guys / gals.
Not sure if this has ever been mentioned but I didn't see anything on it. I recently had this installed into my 06 AT coupe and let me tell you... wow! Takes some AV tweaking to really make it shine but a VERY good investment. Fitiment in the JDM double din is remarkable and my installer had no difficulties with it (though it is somewhat different than the 05 Coupe, he told me).
He did, however, have that problem with the blowing hot air (see sticky). It was fixed in about 12 seconds- thanks again to the forum users!
One thing I wanted to caution you about, however, is that the panel rotates out (while exchanging DVDs or SD cards) in such a way that if your vehicle is in park, it won't rotate fully. It'll bump into your shifter and you won't be able to access either the SD or your DVD.
I'm not saying this would change my mind on the purchase either way, but I wanted to make sure those of you looking at it don't get a rude surprise. You just have to put your car in gear and hold the brake on... no huge deal- and if you have your system configured properly you'll seldom ever need to do that. (Hello Iphone / USB jack / Aux jack)
I have loved every second of driving with the convenient touch screen and excellent quality image.
Let me know if you have any other questions.
Eno
Old Mar 8, 2010 | 03:30 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
By how much does it go too far?
Old Mar 8, 2010 | 04:27 PM
blazeplacid's Avatar
I think most double dins with a hidden cd/dvd slot will hit the shifter
my DNX8120 did it and the Eclipse 5510/6620 had the same issue
Old Mar 8, 2010 | 04:39 PM
jayjay1122's Avatar
Its the same thing for the sedan AT...
I'm primarily using the Ipod and XM but on the rare occasion that I do open the face, I just put the car in neutral.
Old Mar 8, 2010 | 05:03 PM
4DGS's Avatar
Buy a shift **** and shift boot so it clears.
Old Mar 10, 2010 | 07:39 PM
Eno's Avatar
Eno
Thumbs up
Wrather... If you kick it back to reverse gear it's got room- Probably about an inch too far.
Thanks to the others for your feedback as well.
eno
PS 4DG- getting rubber (275 / 245 Yokahama S-Drives) on those wheels as we speak. Can't wait to show em off!
Hope all is well.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Kal Hamm
Jul 24, 2015 08:55 AM
