some issue with the passenger side power door (03 G Coupe)
Since I am gonna remove the door panel to fix the windows motor, I hope to fix the power door lock problem as well. The problem has been there for a long time. I can barely use the keyless or power buttons on both the driver and passenger sides to lock or unlock the passenger side door. It only works well in cold weather. Does anybody know the possible problems? Thanks
Check this post out first:
https://g35driver.com/forums/interio...uator-fix.html
If that doesn't take care of you, post again.
Thanks a lot! I will try this...
rezendvous420
May 31, 2020 01:26 PM
Micale757
Lighting
Apr 8, 2020 10:46 AM
