Audio people: Will this work?
Old May 1, 2010 | 09:18 PM
Derek173's Avatar
I am looking to do a mild upgrade on my 03 Bose coupe. I currently have Infinity Kappa speakers in my doors and I plan to upgrade the rear deck with another pair of Infinity Kappa 6x9 speakers.
I originally purchased the Kappas to replace my front door speakers speakers because they are 2ohm and would work with the factory amp.
Can I use this amp in my setup? I am confused about the ohms. Here are some specs on the amp
Soundstream STL4.320 4 Channel 640 Watt Amplifier
* 4-Channel Class A/B
* Power output:
o 50 Watts RMS x 4 @ 4 ohms
o 80 Watts RMS x 2 @ 2 ohms
o 160 Watts RMS x 2 Bridged @ 4 ohms
* Total Harmonic Distortion (4 Ohm power) - 0.03%
* Frequency Response - 15-25kHz
* Signal-to-Noise Ratio (4 Ohm power) - 96dB
* Damping Factor (100Hz, 4 Ohm) - >200
* Signal Voltage - 200mV-5V
* Potential Current Draw - 60A
* Dimensions: (2.125"h x 6.5"w) - 9.625" Size A
* Channels 1&2 HPF (12dB/octave) - 50-4KHz
* Channels 1&2 LPF (12dB/octave) - 50-4KHz
* Channels 3&4 HPF (12dB/octave) - 15-500Hz
* Channels 3&4 LPF (12dB/octave) - 50-800Hz, or 250-4KHz
Will this amp work with my Infinity Kappa speakers?
Speaker specs:
* 6 x 9" , 2-Way Speakers (pair)
* Power range: 2-110 watts RMS (330 watts peak power)
* Plus One woven-glass-fiber woofer cone with hi-roll rubber surround
* Front accesible tweeter-level adjustment
* Low-distorsion, low-Q woofer motor
* Edge-driven MMD dome tweeter with UniPivot
* Direct connect crossover dongle
* Computer-optimized outboard crossover with tweeter level control
* 2-ohm impedance for extra power (compatible with all factory or aftermarket car stereos)
* Sensitivity: 96dB
* Frequency Response: 35Hz-25kHz
* Top Mount Depth: 3-1/4"
Old May 2, 2010 | 01:27 AM
BuckeyeInMI's Avatar
This info is incorrect. 80 Watts RMS x 2 @ 2 ohms. It's 80 x 4 @ 2 ohms. http://www.soundstream.com/AudioProd...rs/stealth.htm
You'll probably need a LOC to make this work. You need differential balanced inputs on the amp if you're coming from the Bose, and it doesn't look like this amp has it.
Old May 2, 2010 | 01:50 AM
Derek173's Avatar
Great thanks, I was going off the ebay dealers info.
Old May 2, 2010 | 11:54 PM
gl35's Avatar
Don't get a LOC, get an MTX REQ or an MTX REQ5 it has the balanced differential inputs conversion. This was a hard won battle for me. The MTX also has an aux input, which is kinda nice too.
Old May 3, 2010 | 03:38 PM
blazeplacid's Avatar
REQ/REQ 5 is a LOC.....
A generic LOC sould work fine
marsman328
Northern California
Aug 11, 2015 07:29 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Cacoepy
Aug 3, 2015 01:09 PM
Frostbite91
Aug 2, 2015 04:59 PM
