Enough room?
Old Sep 25, 2004 | 09:51 AM
malx's Avatar
Enough room?
I was thinking of installing my Lilliput screen in the dash where the Hazard switch and the ash tray is. Do you guys think there is enough room behind it if I did this? I would cut the hole and put the TV behind it and I would make a metal piece as a frame.
Here are some pics...
Thanks - Joey Avino
malx's Avatar
Re: Enough room?
Another
Thanks - Joey Avino
Old Sep 25, 2004 | 09:52 AM
malx's Avatar
Re: Enough room?
Another shot
Thanks - Joey Avino
malx's Avatar
Re: Enough room?
Last one
Thanks - Joey Avino
Old Sep 25, 2004 | 03:11 PM
wizawuza's Avatar
Re: Enough room?
I assume you're talking about the 7" lilliput?
were you going to take it out of the casing? if not, I really really doubt it'll fit.
If you do,even then i doubt it, but it might fit. I got a xenarc that's not in any housing right now, and my car is taken apart at the moment, so I'll check within the next couple of hours.
I know it's not what you asked, but before you do this, be sure you're willing to look at a screen that's so low.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Sep 25, 2004 | 04:00 PM
malx's Avatar
Re: Enough room?
Yeah it's actually a good spot. I can take it out of the casing. Withwise it will fit with the casing, so I would only remove the back plate or the whole case if I had to.
And yes it's 7"
Thanks - Joey Avino
Old Sep 25, 2004 | 04:44 PM
wizawuza's Avatar
Re: Enough room?
oh the depth is what you're afraid won't fit?
If so, since I don't have the unit, I can't help, sorry. I'm sure you can cut the hell out of a lot of that stuff back there if needed.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
Old Sep 25, 2004 | 05:58 PM
malx's Avatar
Re: Enough room?
Yeah you're probaably right. I just don't want to screw up. Screwing up is NOT an option... lol.
Thanks - Joey Avino
Old Sep 25, 2004 | 09:40 PM
malx's Avatar
Re: Enough room?
Okay I have two pictures. The one above and the one below. The TV would be in the black electric tape. Do you guys think this is a good idea? I would have to do alot of cuttting. If I mess up how much do you think that piece would cost? The TV would rest in between the black electric tape.
Thanks - Joey Avino
malx's Avatar
Re: Enough room?
Two
Thanks - Joey Avino
Old Sep 26, 2004 | 11:02 PM
malx's Avatar
Re: Enough room?
Bump.. any takers? [img]/w3timages/icons/smile.gif[/img]
Thanks - Joey Avino
Old Sep 26, 2004 | 11:36 PM
xlacrosse's Avatar
Re: Enough room?
i think its going too look very bulky in there... if you could step down to a 5" tv, you would prob be ok. Then there will be room left and right of the tv and you can still see the bezel
*ANTI G-Squad Member*
Old Sep 27, 2004 | 08:31 AM
malx's Avatar
Re: Enough room?
If I stepped it down there would be holes where the ash tray and hazard switch would be.
Thanks - Joey Avino
Old Sep 27, 2004 | 09:03 AM
tsolin01's Avatar
Re: Enough room?
would the shifter be in the way for people to see the screen and access it? if it fits thats the only thing that may cause a problem...
Old Sep 27, 2004 | 09:55 AM
xlacrosse's Avatar
Re: Enough room?
hmmm didnt think of that.
