Bluetooth call quality ...
Old May 30, 2010 | 04:43 PM
kacatoo's Avatar
Fellas, I've been a member for a while and usually I get my answers searching the forums but now I need some help. I have a 06 g35 coup, no navi/sat, and my BT calls are choppy. I had 4 phones connected to it and the quality of the calls vary across the board. I want to see if people had simillar problems and if there is a solution.
First, I had a Motorola v620 flip and the call quality was bad, in and out. Then I tested the iphone 3g and it worked well. Damn phone. After that I got all exited and got a Nexus One. What a let down. That ****ty software was not backwards compatible with infinitis or nissan vehicles. I read all about the issue so I understand that particular problem. And now I have a Motorola cliq xt that pairs fine but the call quality is bad. Does anyone have this problem with the cliq? Are there upgrades for the BT software on the g35 to fix this? And has anyone paired a HTC HD2 without problems? Thanks for the help guys.
Old May 31, 2010 | 12:33 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Factory bluetooth is a common complaint.
If you're still under warranty though, take it in and complain. Worst thing that happens is that you get to cruise around in a loaner for a day or two.
Old May 31, 2010 | 01:36 PM
416dawn's Avatar
I had problems with Nexus One , but since upgrade to Android 2.2 everything works fine ( same quality and connection as my old iphone 3G)
Old May 31, 2010 | 08:16 PM
kacatoo's Avatar
The Nexus One connectivity issue is fixed???? Really? What car model do you have? Do you no longer have the problem were the audio did not go thru the speakers, only thru the phone when connected to the bluetooth? It would be nice if that problem did get fixed.
Old Jun 1, 2010 | 09:36 AM
416dawn's Avatar
I have 06 G35 sedan.
And part of froyo(2.2)is bluetooth compatibility fix, as there was lots of connection problems.
I no longer have any lost connection- audio always goes through speakers ( before it was random).
However you will need to upgrade manually- official upgrade will be out in few weeks.
Old Jun 3, 2010 | 11:35 PM
Mustang5L5's Avatar
Same here. Microphone quality blows. Nobody on the other end can hear me.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NyCrAzY
Oct 1, 2015 09:19 AM
