NEED HELP!!!!! Installed aftermarket radio and lost BASS!!!
Old Jun 9, 2010 | 12:08 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by utownmatt22
Would that matter since it's running through the stock bose amp? All I need to do is adjust the frequency or signal that my aftermarket HU is sending to that amp so I can get the correct sound
Please be more specific.
You can't make your headunit send the balanced signal that the Bose amp expects, or compensate for speakers with the wrong resistance.
Old Jun 9, 2010 | 02:28 PM
FCPImport's Avatar
Right but the question is if he is using the factory Bose speakers aren't they 2 ohm which all radios work off of 4ohms. If he were to use an aftermarket amp then he would be fine.
Old Jun 9, 2010 | 02:49 PM
utownmatt22's Avatar
Factory speakers, and factory amp, all Bose. Basically what I'm saying is that the signal that my aftermarket headunit is putting out needs to be "tweaked" so that the amp will pick it up like it's the factory headunit and I get the sound I'm looking for. I've spent all day researching this harness you suggested and from what I can see It's what I need to make it work the way I want.
Old Jun 9, 2010 | 02:51 PM
saywat?'s Avatar
^^hes using the factory bose amp. why do u keep emphasizing the 2ohm speaker info? OP ur issue is the bose amp. btw fak bose lol
Old Jun 9, 2010 | 02:54 PM
Originally Posted by saywat?
^^ OP ur issue is the bose amp. btw fak bose lol
yeah I figured that one out hahaha, not many bose fans out there lol
Old Jun 9, 2010 | 03:12 PM
The only Bose fan is one who doesn't know better.
Old Jun 9, 2010 | 03:16 PM
Very nice hahahaha, one day when I save my money up I'll be swappin all my speakers out for Alpine.
Old Jun 9, 2010 | 03:47 PM
ordered the harness, found it for $39!!! Should be here first part of next week, will update and let you guys know what happens.
Old Jun 9, 2010 | 04:30 PM
FCPImport's Avatar
If he was hooking the radio directly to the amps wiring there would be an impedance issue. If he is buying the pac adapter then this will correct it and hopefully get back some of that missing bass.
Old Jun 21, 2010 | 06:29 PM
worked perfectly, thanks to everyone for their help!!
Old Jun 21, 2010 | 07:45 PM
^ That's with the PAC ROEM-NIS2, right?
Old Jun 28, 2010 | 09:13 AM
Exactly, ran into a minor hicup, the instructions don't say anything about the +high and +low for each speaker, so I just twisted them together and wired them to the + from the harness coming out of the radio. Other than that it was a breeze, and took little to no adjustment to get better sound than I actually had before with the stock deck, and I'm still using the Bose amp and speakers!
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 12, 2015 05:16 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Tom_P
Jul 24, 2015 04:05 PM
