replacement for the stock bose woofer?
does anyone know where could I find a replacement for my stock bose woofer?
mine stopped working and i would like to just replace it instead of buying a different subwoofer and going through an entirely different installation process. i think the separate amp on the woofer is the part that went out on me, so if i could at least buy that part i should be set. the speaker itself doesn't look damaged. I like the sound the BOSE makes so if anyone on here could help me out on this you would be my new hero!! :bowdown: ps. i took out my back panel because my high mount stop light stopped working so im absolutely ready to install a replacement woofer right now 2003 g35 sedan w/bose thanks to anyone for helping me out |
The amp on the rear deck powers everything in the Bose system. If that amp goes out, you won't get any sound at all.
8" woofers are not common. Your choices are here: http://www.woofersetc.com/index.cfm?...date+Selection My budget recommendation would be this one: http://www.woofersetc.com/p6960/P1S4...-Subwoofer.htm Which should be ok with the weak output from the Bose amp. This one's probably the best bang-for-buck one, but would be very underpowered with the Bose amp. http://www.woofersetc.com/p5504/8W3V...-Subwoofer.htm I'd highly recommend adding a mono channel amp in the 200 watt RMS range to get the most out of either of those subs. |
thanks for all the info
i might decide to go in that direction if i cant find anyone willing to sell me the stock bose speaker with the wire harness im looking to see if maybe someone on here has upgraded out of their stock bose speaker and is looking to maybe sell me that one? i want the sound to be stock if at all possible i cant find the speaker at infiniti parts usa so im guessing its extremely difficult to find through a catalog |
Originally Posted by incubus3612
(Post 5198078)
if you like the stock sound cool junk yard or such is gonna be your best bet have you pulled the driver and checked to see if its blown? Use a multimeter and turn it to 200ohms or whatever the lowest impedance setting is. Should get around 2 ohms. If you get ~2ohms the sub works and it might be the amp or possibly a loose connection if you do replace the sub you need to find one that will do free air |
Yeah, the stock sound definitely sucks, I'd sell you mine, but I want to have it around to return the car to stock in case I ever sell it.
Originally Posted by blazeplacid
(Post 5198319)
have you pulled the driver and checked to see if its blown? Use a multimeter and turn it to 200ohms or whatever the lowest impedance setting is. Should get around 2 ohms. If you get ~2ohms the sub works and it might be the amp or possibly a loose connection if you do replace the sub you need to find one that will do free air and the speaker itself works too. my only guess is whatever that thing is inside the plastic harness that converts cables before they reach the cone might be out? :dunno: either that or my wiring went wrong somewhere... |
i didnt know we had subs in the car... i just thought they were 6x9s
Kicker
General Type Component Size 8" Impedance 2Ohms Voice Coil(s) Single Sensitivity 85.6dB Peak Power Handling 200 Watts RMS Power Range 100 Watts Surround Material Polyfoam Ribbed Cone Material Polyimide Frequency Response 30 - 500Hz Installation Cutout Diameter or Length 6-15/16" Top Mount Depth 4-1/16" Sealed Box Volume 0.5 - 1.2cu. ft. Ported Box Volume 0.66 - 1.2cu. ft. Would this work with the stock amplifier on the g35 sedan base 2003??? I want to replace only the woofer...thx |
Originally Posted by demento
(Post 6871321)
Kicker
Originally Posted by Wrathernaut
(Post 6871374)
It would be horrifically underpowered to the point it might barely move, and the impedance is too low. Look for something 4 ohm with RMS around 20w.
Thx for your reply wrathernaut.ill try to do some research on that! |
Does someone knows exactly what kind of woofer works with the bose amplifier??? Everything i have on my g35 is stock...i want just to replace the woofer...thx
Add a second amp capable of powering a "real" 8" woofer that works well in an infinite baffle setup and reinforce the hell out of the rear deck and you're set.
Just replacing the woofer without replacing the amp is wasted effort. There's virtually nothing that's below 100w RMS. Lowest I can find readily available is the JL 8w1v2, at 35-150w RMS, but again, it takes power to overcome the larger magnets in subwoofers, so the 25-ish watts the bose amp puts out is not going to get it to move much. |
(Post 5196540)
(Post 6871838)
Originally Posted by Ednica87
(Post 6946199)
Hey I'm trying to access those links and they're not working. What are the specifications on the sub to look for better replacements? Thanks
You want an 8", 4-ohm subwoofer. You may need to make a spacer or cut the rear deck depending on the actual size of your woofer. Budget recommendation for working with Bose amp: Rockford Fosgate P1S4-8 (about $60) Best bang-for-buck, but needs more power than the bose amp puts out: JL 8w3v3-4
(Post 6946200)
Hey also I was wondering, If I do replace the stock sub I know I would have to replace the stock amp, but Does that amp power all the speakers or justg the reaer deck? Thanks
