just a QUICK question for anyone that can help...
Old Oct 6, 2004 | 02:40 AM
g_thirtyfive's Avatar
i was wondering if anyone knew on here or a forum about the "high-level input" for stock decks? ive just recieved my screen, but currently my sub is hooked up to my stock deck, and im gonna try a DIY to hook up the screen. hope that made sense
Old Oct 7, 2004 | 09:06 PM
Re: just a QUICK question for anyone that can help...
TTT
Old Oct 7, 2004 | 10:25 PM
wizawuza's Avatar
Sorry but I don't follow your question?
Currently your sub is hooked up to the stock deck? Directly??
My setup is stock deck going to high level inputs of a 6 channel amp, which then feeds 4 channels into the 2 fronts and 2 rears, and then bridge the last two channels to hit the sub.
Do you have the the bose system? Give us more information on what you have, hopefully that'll help to answer your question
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Oct 7, 2004 | 10:52 PM
justICE's Avatar
Confused on the question. Are we talking about a sub or a monitor?
-JustICE
Old Oct 8, 2004 | 12:26 AM
haha sorri i knew that didnt make much sense. k, rite now i have the bose system, with a 10w7 and a JL 500/1 amp hooked up to the deck through the high level input (for stock decks) im wondering how i can UN hook that and install my kenwood ddx7015 into my car? if that made sense...lol
Old Oct 8, 2004 | 08:57 AM
wizawuza's Avatar
From what I can tell, you're trying to put a double din unit into there... if so, search up double din, there's lots of info out there.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
Old Oct 9, 2004 | 06:19 AM
HA...use the search. id have more luck going to my grandma for answers...lol :P
Old Oct 9, 2004 | 11:43 AM
RamboRami's Avatar
G35driver.com Moderator
heh what you need is the double-din dash kit from japan and that should cost you around $400, it will make installation smooth and easy but you will have to dump your bose system+mini bose amp. Your ddx "screen" will power your in-car speakers and your 500/1 amp will power your SUB, your reardeck bose speakers will be useless then (but thats a good thing [img]/w3timages/icons/smile.gif[/img])
Why you need the kit you ask? Because behind the front face of the stock/bose system is a circuit board that run from the bottom of the deck all the way up to the A/C air controls and so you can't just remove one without the other. The $400 double-din kit comes with a new A/C controller (with the buttons) and a big 2-din size hole in the dash (plenty for your ddx unit)
good luck.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
KevinnnVo
Oct 14, 2024 04:33 PM
408G35Sedan
Feb 23, 2022 06:46 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
