FS: OEM Nissan/Infiniti iPod integration kit $150
Old Aug 19, 2010 | 01:23 PM
kidtronix's Avatar
Optional
Thumbs up OEM Nissan/Infiniti iPod integration kit $100
$100.00 — OEM Nissan/Infiniti iPod integration kit
Fully functional and in mint condition. Save some cash and buy it used!
This kit integrates with the OEM head unit.
Nissan/Infiniti OEM factory iPod integration kit. You can have complete control of your iPod through this unit, complete access to your music conveniently through your factory radio controls. This will also display Song, Artist, & Album title on the factory radio display. The integration kit is designed to override your satellite radio input. While the iPod is plugged in the satellite radio function is inoperative until the iPod is unplugged.
Label is missing since it was installed with the adhesive foam mount on the label side. If your G35 is a 2003 model and it is not pre-wired for satellite radio, then you will need to purchase the pre-wire harness in order to connect the ipod unit, to your factory radio.
If you want more info, please search the site as there are a ton of conversations/resources about this system. I've included some FAQs below from g35parts.com.
Thanks for looking. Please PM me if you're interested!
FAQ’S:
Does this unit charge my iPod while plugged in?
– Yes, it does. ---
What can I control with my steering wheel switches?
– Song skip and volume only. --- '03-'04 & '07-'08 Models do not have skip compatability through the steering wheel controls.
Is there a way to make it play random?
- As long as u have it in shuffle mode before you actually put the connection cable in then it will stay in that mode until you change it to a different one i.e. searching for a particular song or play list. ---
Is this a factory part?
– Yes, & no. Nissan makes it for certain Nissan models. We have adapted it to be used in the Infiniti models. Your local Infiniti dealer will most likely be unaware of this accessory. ---
Can I still use my satellite radio after I have this installed?
– Yes, but you will have to have the iPod unplugged from the iPod harness. The integration kit is design to over ride your satellite radio.
Will this work with all model G35's?
– No, this model does not work with early 2003 G35s (production date before 09/02) as they are not satellite capable and 2007+ G35s that are equipped with Navigation and XM's Navtraffic.
NISSAN 284H0-EA00B
Model No: EN-1254U
Part No: 286-6761-01
Attached Thumbnails OEM Nissan/Infiniti iPod integration kit 0-img_5594.jpg
Old Aug 27, 2010 | 04:15 PM
kidtronix's Avatar
Optional
BUMP—make me an offer if youre interested. Please PM me if so.
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
