navi problems
Old Oct 11, 2004 | 07:39 PM
steckles's Avatar
navi problems
I have a problem with the navi. It sometimes goes black for days and the little arrow does not follow me when I dirve. Does anyone know what the problem could be??? I bought it used and it was recently installed in my car. And if I push the where am I, nothing will be displayed.
THANKS
Old Oct 11, 2004 | 08:02 PM
dave's Avatar
Re: navi problems
What kind of navi do you have?
Are you saying the navi was just installed?
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Oct 12, 2004 | 03:27 PM
steckles's Avatar
Re: navi problems
It was just installed...It goes from working to blank screen occationally. The navi is from infiniti. I still can't get the arrow to follow me
Old Oct 12, 2004 | 08:57 PM
dave's Avatar
Re: navi problems
After about a year of reading several G35 forums, I have NEVER heard of anyone installing the stock navigation system in a G35 after it was manufactured. Are you saying you have that on your car??
There have been a couple of posts recently about blank screens. What happens if you press the "D/N" button?
When the screen is blank, does anything work? What happens when you press info?
You can see if the navi system is still working by pressing "Dest", Press "Enter" on the joystick, Press "Enter" on the joystick again, then wait about 5 seconds and Press "Enter" on the joystick again. That will tell it to take you "Home", and the directions should start shortly.
I wonder if there is a wire that is loosly connected to the screen?
GroundingGear™
2003 Yamaha YZF600R
Old Oct 14, 2004 | 03:15 PM
steckles's Avatar
Re: navi problems
My screen is working now; however, it is still not following me when I travel. Does this mean that my antenna is not working properly or something. Thanks for the help by the way
Old Oct 14, 2004 | 07:45 PM
dave's Avatar
Re: navi problems
The stock navi uses two methods to keep your position correct on the map. First, it gets information from the GPS antenna that is in the dash. It also uses speed data to fill in the gaps from the GPS.
If it looks like you are not moving, neither of those imputs are making it to the unit. Sounds like time to make sure all the wires are connected correctly.
Could you post pics of your install?
GroundingGear™
2003 Yamaha YZF600R
Thebaws11
Jul 2, 2021 11:36 AM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
