2003 g35c Bose (Blowes) amp Bypass?
Old Oct 14, 2010 | 11:09 PM
redline35gtr's Avatar
I wanted to do a DD install but don't want to get a new amp nor do I want to use the factory amp. Can I just do amp bypass? If so how? Thanks all Photos of bypass would be great.
Old Oct 15, 2010 | 03:26 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Your new headunit won't have 6 powered channels, so you're going to have to get another amp or keep the bose powering a couple channels.
You can get a cheap 6-channel amp to replace the Bose for under $300http://www.woofersetc.com/p8649/STL6620--Soundstream-6-Channel-620-Watt-Stealth-Amplifier.htm and not worry about your channel that relies on the Bose amp sounding even crappier and with more noise than before, since your new headunit isn't outputting a differential-balanced signal.
I don't think I've ever seen anyone who bypassed it post up the pictures, and I'm a good 10 hours away from the service manuals to tell you which wires connect with which to bypass though. I'm sure if you search this forum enough, you'll find a previous post of mine with wire colors for that year specified.
Old Oct 15, 2010 | 11:31 AM
Okay, here's the wires:
INPUT:
Rear:
Left +: Light Green
Left -: Purple
Right +: Blue
Right -: Pink
Front
Left +: White
left -: Orange
Right +: Orange w/ blue stripe
Right -: White w/ blue stripe
OUTPUT:
Woofers:
Left +: Blue w/yellow stripe
Left -: White w/green stripe
Right +: Blue w/red stripe
Right -: Blue w/white stripe
Rear:
Left +: Green w/yellow stripe
Left -: Black w/yellow stripe
Right +: Brown
Right -: Black
Front
Left +: Green
left -: Red
Right +: Grey
Right -: Yellow
Old Apr 18, 2019 | 02:50 AM
Dr4886407's Avatar
04 G35 coup
So which exact colors need to be bridged? For the bypass
INPUT:
Rear:
Left +: Light Green
Left -: Purple
Right +: Blue
Right -: Pink
Front
Left +: White
left -: Orange
OUTPUT:
Woofers:
Rear:
Right +: Brown
Right -: Black
Front
Left +: Green
left -: Red
Right +: Grey
Right -: Yellow
Old Apr 18, 2019 | 05:44 AM
Scorpi0's Avatar
Connect the input wires to the matching (speaker/polarity) to output wires.
For example: The input of the Left+ should connect to the output of Left+
The input of the Right+ should connect to the output of Right+
Old Apr 18, 2019 | 09:55 PM
Dr4886407's Avatar
04 G35 coup
I had one wire left over it was light blue teal. Do I leave it alone?
Originally Posted by Scorpi0
Connect the input wires to the matching (speaker/polarity) to output wires. Thanks for the help! btw
nissandrifter32
Dec 22, 2015 04:28 PM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
mattdg35
Sep 14, 2015 11:28 AM
