Noise in AUX ? can you help?
Hi everyone,
My problem is when I press AUX button and connect the video & Audio cable I hear a noise even if I do not play anything. The same thing when I connect my digital camera , the pics are ok but I hear noise even if the volume is down!
Infiniti g35 2007
any ideas...
Infiniti g35 2007
any ideas...
1) Is the noise there when you have it set to radio with the radio volume all the way down?
2) Is it factory Bose?
3) Does the noise increase/decrease in volume if you adjust volume with the source set to AUX?
4) Is the noise present if the radio is on, but the car is not running?
5) If the noise is only present when the car is running, does the noise slowly change pitch when you slowly raise the RPMs?
Oh and #6, most important:
2007 should still be under full warranty.
Take it to the dealer and make them fix it.
I asked that Q because I have connected my cell phone Nokia with Navigation into the AUX and managed to make it continue to play even while in motion
. It is the factory one. The noise increase when I adjust the volume. I have to keep the volume realy low to avoid the noise. I connected the digital camera the noise does not apper till the volume is in the middle so it could be related to the cable! but even when the volume is all the way down you still feel that the speekers are on! It could be normal.!!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
