Wiring Diagram - Alarm
Old Oct 23, 2010 | 05:25 AM
Itzmy04G35's Avatar
Disregard my previous....for future ref. for anyone else....
2004 Infiniti G35 Coupe Car Alarm Wiring Guide
Battery Constant 12v+ Positive Wire (+): White/Blue
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/White (+) Or White/Red (When installing a remote starter, you must use both starter #1 and starter #2 wires. Both wires must be connected to the starter/cranking output wire from the remote starter or the vehicle will not remote start when the engine is cold.)
Starter Positive Wire Location: Ignition Switch Harness
Secondary Starter Positive Wire (+): White/Green (When installing a remote starter, you must use both starter #1 and starter #2 wires. Both wires must be connected to the starter/cranking output wire from the remote starter or the vehicle will not remote start when the engine is cold.)
Secondary Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): White/Black
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red/Blue
Parking Light Positive Wire Location: In Drivers Kick Panel, Harness Heading To Rear Of Vehicle
Power Door Lock Negative Wire (-): Yellow (Test these wires while turning the key in the driver door key cylinder.)
Power Door Lock Negative Wire Location: At Drivers Door Module In Drivers Door
Power Door Unlock Negative Wire (-): Light Blue (Requires Double Pulse). Test these wires while turning the key in the driver door key cylinder.
Power Door Unlock Negative Wire Location: At Drivers Door Module In Drivers Door
Door Trigger Negative Wire (-): Yellow And Pink (Use Both). The drivers door is a yellow (-) pin 14, the passenger door is a pink (-) pin 10. When connecting to an alarm system, use both door trigger wires and diode isolate.
Door Trigger Negative Wire Location: At BCM, White 12 Pin Plug, See Note *4
Domelight Supervision Wire: Turns On With Unlock
Domelight Supervision Wire Location: N/A
Trunk Release Negative Wire (-): Pink
Trunk Release Negative Wire Location: At BCM (Brown Plug, Pin 76). The BCM (body control module) is located in the drivers kick panel, the BCM has 4 white plugs and 1 brown plug.
Horn Negative Negative Wire (-): Green/Black
Horn Negative Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire Not Black Or White/Blue
Tachometer Wire Negative Wire Location: At Any Ignition Coil
Brake Light Positive Wire (+): Pink/Blue
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Disarms With Unlock, Single Pulse Disarms
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft Wire (-): Transponder Anti-Theft System. Requires Bypass Module And Extra Ignition Key.
Factory Anti-Theft Wire Location: Transponder At Ignition Switch Tumbler
Immobilizer Bypass Module: Required: Yes
Type: Transponder Part #: 556U or 555U
Old Oct 23, 2010 | 06:01 AM
Itzmy04G35's Avatar
on the same topic, can anyone tell me the wires needed to instal a "window up/down" control?
Old Dec 22, 2012 | 03:29 AM
Billy Meade's Avatar
awesome, thanks
Old Jan 25, 2013 | 02:26 AM
PlastiDippinG's Avatar
know this is old,but if the OP ever sees this,THANK YOU SOO MUCH MY DUDE,HELPED AND SAVED ME HUNDREDS IN DOING MYSELF WITHOUT NEEDING TO GET RIPPED OFF BY A SHOP.MY MAN THANKS
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
master111
Oct 6, 2015 01:36 AM
9tray turbo
Sep 29, 2015 10:22 PM
