Please help me keep my nav voice!!
I hadn't considered using a 5/6 volt one... by just wiring in a 3v LED in series with the relay coil, it'll drop the voltage down to a safe level for one.
If you pick up one of these:
http://store.americanmicrosemiconduc...12-14d5-6.html
You can switch the audio channel and mute the other three channels.
I'll whip up a wiring diagram for that one in a few hours after I get off work, it seems like the optimal solution, and reduces the cost to somewhere around $10-15.
Hehe also I prolly forgot to close some of the unsed wire.. Lesson learned..
I hope it is the fuse and not something else..
Thanks for taking the time!!
I will do it as soon as I get more time..
You were right about the dash lights and the tail lights. It was a blown fuse..Thanks.
I am having the same problem but in my case i need to get everything. My nav dont even power up, so i need help with the wire to power it up and to be able to use the monitor features that come with the factory navi.
yucakia, could you be a little bit more specific?
You're putting in an aftermarket radio, but your factory navi completely doesn't work?
Have you checked your fuses?
Looks too much of a pain just to get the voice, I haven't used the factory unit at all since I got a new phone which has navigation. Wrathernaut thanks for donating so much of your time in helping us with our audio problems.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
