Custom sub box build help!
Old Dec 19, 2010 | 01:18 PM
dagan30's Avatar
so I have 2 fi bl 15's im looking to do a custom enclosure in the whole trunk(2004 g35 coupe) if anyone could help me get started on some ideas that would be great... thanks
Old Dec 19, 2010 | 01:30 PM
eggyhustles's Avatar
Won't fit those
You're looking at 4 cubes per before port and sub displacement. Only way would be a wall.
Old Dec 19, 2010 | 01:50 PM
dagan30's Avatar
even if it was a sealed box? im not looking to get the full amount of cubes just use my entire trunk fiberglassed or what not... i just need a couple ideas i may just put 1 of the 15's and use all the sapce....
Old Dec 19, 2010 | 02:33 PM
Bl's perform poorly sealed
It tells you right on the fi site that its a ported only woofer
Old Dec 19, 2010 | 02:45 PM
kennymo's Avatar
there would be no way to even get the box into the trunk.
Old Dec 19, 2010 | 02:48 PM
Agreed
for spl, i'd do 2 8's or a good 10 in a 4th order
2 10's would be nice, but def wont fit
Old Dec 19, 2010 | 05:33 PM
BOXOLOGY's Avatar
That isn't impossible but crazy and unique costs. It would require a 3-part enclosure and $1500 just as a starting point for the labor and materials in the hands of an experienced fabricator. Know that you will also be adding a couple hundred pounds easy to the trunk and your charging system upgrade isn't going to be cheap.
You can easily figure 3 grand just to get the ball rolling before equipment.
Don't forget 10 bucks for a roll of duct tape for your roof gasket, though
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
RA081024
Sep 18, 2015 12:20 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
Mikesta
Sep 10, 2015 05:14 PM
