HELP- Audio, dvd, and climate not working!
Old Oct 29, 2004 | 09:22 PM
ChuckP's Avatar
I need advice from the experts. I wired up my JL 300/4 to my speakers, i was all done and loving how it sounded. Whne i saw that the only two wires left on the bose harness was the power and ground. ( i think yellow and black). So without thinking i snipped both of them at the same time, i should have known, Now my bose, navi and climate controll are all not working!! i check all my fuses in the engine and drivers side, next to the dead pedal, and all of them are fine, what do i do? please help me out, thx
Old Oct 30, 2004 | 01:40 AM
KPierson's Avatar
Re: HELP- Audio, dvd, and climate not working!
Did you chec the fusebox behind the battery? There is a small fusebox hidden in the battery compartment that most poeple don't see. Also, try disconnecting your battery over night and hooking it back up in the morning, if no fuses are blown.
PM SFLG35, he has experiance cutting all the wires at once in his G35...................
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Oct 30, 2004 | 02:45 AM
ChuckP's Avatar
i checked that fuse box too, nothing, if i put the bose amp back in, do you think infiniti can say i voided my warrenty by cutting those amp wires? what could i do?
marsman328
Northern California
Aug 11, 2015 07:29 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Cacoepy
Aug 3, 2015 01:09 PM
Frostbite91
Aug 2, 2015 04:59 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
