need help for Jensen DDin conversion
Old Jan 4, 2011 | 08:53 PM
jmgjj's Avatar
I got all parts based on Wrathernaut's famous thread, very helpful and informative. I got a Jensen VM9424 head unit. Before I take my car apart, I think I should do the wiring first. I was able do most of the wiring except two wires which I don't know where they should go. Both wires are from the harness of my head unit. One is in brown (mute) and the other one is in green/white (reverse). Since I have used up all the wires from my Metra 70-7550 harness, I have no idea where should these two wires go to. The Metra 70-7550 does not have wires with these two color....
My car is 04 seden with no bose, no navi
Old Jan 5, 2011 | 03:05 AM
Unleaded91's Avatar
Does your HU have a backup camera input? Maybe the green/white wire is for the HU to detect when you're in reverse gear.
Old Jan 5, 2011 | 11:10 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
You won't use the mute wire, and unless you have a reverse camera, that wire won't be used either.
Old Jan 5, 2011 | 12:23 PM
jmgjj's Avatar
thanks
so I will just leave them unused.
Old Jan 6, 2011 | 10:22 AM
blazeplacid's Avatar
yup, either tape em off or just cut enough wire off so you wont have any issues
Marlin84
Apr 1, 2020 12:52 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
twentyeggs
Sep 11, 2015 03:58 PM
06G35Kurtis
Aug 23, 2015 12:24 AM
