Plug & Play Sirius satellite install
Old Jan 9, 2011 | 11:18 AM
woodsnazi's Avatar
I just bought a used 08 G37 coupe and want to use the Sporster 5 plug & Play unit that I take in and out of my Sedan for my work truck.
Is there an adapter that you can use for the 3.5 mm Plug from the Sirius unit to connect to the Ipod link in center console or something to adapt to one of the three audio connections
Or do I need to get one of the Antenna links like I have in my G35 sedan and does anyone know if it would be the same?
Old Jan 9, 2011 | 01:32 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Are you talking about a wire like this:
You can find those at any wal-mart, radio shack, best buy or target.
Or does your G37 only have the iPod connector?
Old Jan 9, 2011 | 02:48 PM
woodsnazi's Avatar
Mine has a a long thin Plug to adapt an I Pod and also the the red white yellow plugs. I have never seen those adapters like in your picture below the cables. That might work for what I am trying to do. I think I need 3.5mm male plug.
Old Jan 9, 2011 | 03:42 PM
Just put the radio to AUX and use the 3.5mm to rca cable pictured above.
Old Jan 20, 2011 | 10:33 AM
woodsnazi's Avatar
Smile Thank You
did what you said,,,,After I got into installing it, I Figured out that I had that wire in my junk draw from another player. That saved a lot of behind the dash work that I didnt have to do
Frostbite91
Aug 20, 2015 07:20 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
ghost_g35
Aug 7, 2015 10:31 AM
