jl hd750 cut off on hard hitting songs
Old Apr 2, 2011 | 11:27 AM
blk35's Avatar
I wanted to know if anyone here who has a jl hd750 that cuts out on hard hitting bass songs. I am using the factory HU audio control LC6 and epicenter.The amp was sent back since is it one of the recalled 750.1. Red top optima batt less than a month old, any suggestion thanks in advanced.
Old Apr 2, 2011 | 12:43 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Are you connected directly to the headunit, or are you tapping the audio signal after the bose amp? The bose amp cuts bass heavily.
If not, make sure you have very solid grounds and power connections (unpainted metal, and straight to the battery, respectively).
Old Apr 2, 2011 | 01:05 PM
blk35's Avatar
i think i am ill have to check when i get home. the grounds are solid checked those connections. so no settings could cause it?
Old Apr 2, 2011 | 01:07 PM
blk35's Avatar
if i am in the conx from the bose amp what can i do to eliminate this?
Old Apr 2, 2011 | 01:24 PM
eggyhustles's Avatar
Bypass the amp and go from headunit straight to the audio control unit
ditch the epicenter too..those things do more harm than help.
Old Apr 2, 2011 | 02:18 PM
blk35's Avatar
ok, used another amp on the system no cut out on the bass at all now what can that be the amp itself? jl hd750?
Old Apr 2, 2011 | 09:06 PM
nar93da's Avatar
Is the yellow LED light coming on when it cuts off, indicating low impedance?
Old Apr 2, 2011 | 09:49 PM
blk35's Avatar
Yea it does.
Old Apr 2, 2011 | 11:32 PM
In that case, wire the sub for 4 ohm instead of 1 ohm and you should be fine, assuming it's a dual voice coil sub.
If it's a single voice coil, well, you got a mismatched sub for that amp, or the sub is screwed.
Old Apr 3, 2011 | 12:15 AM
The amp would(well should) go into protect right away if it's wired down to an ohm load it cant handle
Old Apr 3, 2011 | 12:29 AM
nar93da's Avatar
According to JL the ohm load needs to be above 1.5 ohms. What sub is it?
Old Apr 3, 2011 | 12:09 PM
blk35's Avatar
the sub is 13w7.
blk35's Avatar
any links on how to wire for 4ohms, im not the best at audio, thanks in advanced.
Old Apr 3, 2011 | 12:17 PM
blk35's Avatar
so with the impendance light coming on doenst mean the amp is bad? just that the sub is wired wrong?
Old Apr 3, 2011 | 12:42 PM
http://mobile.jlaudio.com/support_pages.php?page_id=145
