Upgrading to a 220 Amp Alternator
Old Apr 30, 2011 | 04:23 PM
TwilightSedan's Avatar
I'm surprised there isn't a detailed DIY on this. Hint hint g35man04. I just installed a pretty powerful sound system and it's draining bad. Lights are dimming, lagging up shifting, lagging downshifting, actual noticeable loss of power at low rpm cruising when the bass hits. It's pretty ghetto. I need a serious fix if I want to run this system. There is a 220 amp alternator available for our cars. Uses a smaller pulley so I'd need a different belt and a thicker cable running to the battery. According to what I've read g35man04 write. A better battery may be needed as well. If someone has done this help me out or give me some other suggestions. From what I understand, Capacitors don't solve the problem and second battery's still strain alternators. By the way, I've got an 03 Sedan and am trying to push about 640 watts RMS. Amp says it's 1800 watts at 2 ohms, that may be a little over stated.
Old Apr 30, 2011 | 04:45 PM
eggyhustles's Avatar
What amps?
If you're gonna swap alts, go all the way and get a 320 amp
Old Apr 30, 2011 | 05:06 PM
320 amps
These alternators produce more power by decreasing the size of the pulley. More revolutions equals more power production. They're wound more as well. This means you lose HP from the motor that goes into electrical energy production. I don't plan on running a Christmas lights with it during the holidays. I just need to figure out how best to power my amp.
Old Apr 30, 2011 | 05:09 PM
well, what amps are you gonna use
Old Apr 30, 2011 | 05:12 PM
Thinking about this alternator http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content
for the Kenwood 9104D at 2 ohms.
Old Apr 30, 2011 | 05:14 PM
You don't need an alt for that
Big 3 + batt is enough.
Use that alt money toward better amps
Old Apr 30, 2011 | 05:29 PM
Is there a big 3 kit u can buy?
Old Apr 30, 2011 | 05:38 PM
not that i know of
Old Apr 30, 2011 | 05:55 PM
eljoker's Avatar
just google big 3, its super easy to do.
http://forum.ecoustics.com/bbs/messages/4/255554.html
Old Apr 30, 2011 | 08:17 PM
Anybody have any experience with how effective a big 3 upgrade was on our cars? I'm assuming that a big 3 would work if restriction is the issue. Not sure how effective it would be if the alternator isn't producing enough amperage.
Old Apr 30, 2011 | 08:24 PM
dreamweaver's Avatar
its quite easy to change i went with a 260 amp and wow major improvement.. and added grounding
Old May 1, 2011 | 09:32 AM
Who's was yours made by?
Old May 1, 2011 | 11:08 AM
KPierson_'s Avatar
The big 3 should be the first thing you do. Even if you got with a bigger alt you should still do the big 3 for maximum current flow. So, if it has to be done regardless you might as well start there and see if it makes a difference.
I would think that the big 3 alone would be enough for what you are trying to do.
Old May 1, 2011 | 11:13 PM
grovefromnh's Avatar
I did 'the big 3' and put in a 'yellow top' battery when I replaced everything. No problems using the stock alt.
Old May 1, 2011 | 11:17 PM
I am using 2 400 watt Focal amps
