FS: Kicker ZX700.5 5 Channel Amplifier
*******SOLD*******
I no longer need this amplifier. It is an all in one amplifier solution that will power the usual 4 channels + a mono subwoofer channel. I am asking $225. According to the factory test sheet, this amp puts out 990 watts total!
Here are the specs:
ZX Series 5-Channel Class AB with Class D Subwoofer Channel Car Amplifier
Channel 1-4 RMS Power Rating:
4 ohms: 70 watts x 4 chan.
2 ohms: 85 watts x 4 chan.
Subwoofer Channel RMS Power Rating:
4 ohms: 210 watts x 1 chan.
2 ohms: 420 watts x 1 chan.
RMS power output: 700 watts total
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection, Kicker 09ZISL required and sold separately
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Subsonic Filter (24 dB at 25 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 20"L x 9-5/8"W x 2-1/8"H
Here are the specs:
MOSFET power supply
