Need Advice for Speaker Setup
Old May 26, 2011 | 07:58 PM
KingCobra's Avatar
Hi Guys,
So I'm looking to upgrade my speakers in the back and my tweeters...
Currently I have:
- Headunit: Stock Non-Bose
- Fronts: Polk DB651 Coaxial Speakers
- Rear: Stock
- Tweeters: Stock
I'm thinking of the following:
- Fronts: Replace Db651 with Polk DB6501 Components
Amazon Amazon
- Rear: Put the DB651 that I had in the front in the rear
- Tweeters: Db1001 Tweeters to replace the stock ones
Amazon Amazon
What do you guys think? Am i missing something? Do the tweeters already come with the DB6501 set so I dont need to buy the Db1001 seperately?
Old May 27, 2011 | 12:42 PM
KingCobra's Avatar
Anyone?
Old May 27, 2011 | 12:59 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Well, the DB6501s have their own tweeters, so you don't need the db1001s.
Old May 27, 2011 | 02:05 PM
Naveed2126's Avatar
I've been debating as well. I think I'm gunna go with JL Audio TR-650CXi's all around and the TR-050CT tweeters. I have a single 10" sub setup, which makes the bass over powering at higher volumes. I don't plan on running an amp with the interior speakers. I believe just a speaker swap will balance the sound. What you mentioned above sounds good. Are you currently running a sub combo at all?
Old May 27, 2011 | 09:23 PM
eggyhustles's Avatar
Amp you speakers, bro.
Old May 28, 2011 | 10:01 AM
Ocuriel's Avatar
Makre sure you listen to those polks, not a bad choice, but not everyones cup of tea either.
Old May 30, 2011 | 02:13 AM
KingCobra's Avatar
Do you mean the 6501 come with seperate tweeters i can use to replace my stock tweeters? I really want to replace my stock tweeters since they sound like total junk...or do you mean the speakers themselves have seperate tweeters in them? Sorry if its a dumb question, still learning about the diff types of speakers
Also, im not going to get an amp for now until i swap out my headunit for a DD and even then the new headunit would be good enough i think..
Old May 31, 2011 | 03:02 PM
KingCobra's Avatar
^ anyone?
Old May 31, 2011 | 06:02 PM
KingCobra's Avatar
Ended up getting the Polk MM6501
Thanks for the help everyone
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
6spdGspot
Oct 5, 2015 01:55 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
