What lines to tap for subs?
Old Nov 23, 2004 | 04:45 PM
ChuckP's Avatar
I am putting in my JL 500/1 and my 2 eclipe 10's this thanksgiving weekend, but i have one question. Should i tap the 6.5s in the quarter pannel or the 6x9's, or the front compts? I have a JL remote bass ****, so thats how im goin to adjust my bass. But i recall an installer trying to explain to me about fadding foreward and back afecting the subs? please give me some advice, thanks a lot guys and have a great thanksgiving.
Old Nov 23, 2004 | 08:31 PM
justICE's Avatar
Re: What lines to tap for subs?
I use the JL bass **** too. Works great for attenuating the bass. From your post it sounds like you intend to splice the wires after the bose amp. You should just splice the rear wires out of the hu. Fading will effect the sub volume but that is why you bought that JL bass ****=). You have more flexibility with your gain settings when you use that ****.
-JustICE
Old Nov 23, 2004 | 08:45 PM
Shonuff's Avatar
The rears 6.5's from the head unit before amplified.
'04 6MT DG/DG, aero, nav, premium, custom fiberglass 12" sub box
North Jersey
Old Nov 23, 2004 | 09:03 PM
ChuckP's Avatar
no Justice, i no longer got the bose amp in there, a 300/4 JL is in its place. i intend to splice b4 the amp for sure. Shonuf are you sure i should take the 6.5's? wouldnt the 6x9's be better because those were originally for bass? or are both lines the same? thx for you help
Old Nov 23, 2004 | 10:28 PM
justICE's Avatar
Now I am confused. You currently have a 300/4 in there correct? So do you have the 6.5" and 6x9's on the rear channels together?
-JustICE
Old Nov 23, 2004 | 10:50 PM
justICE's Avatar
another thing to consider: I do not remember the resistance of the bose speakers (remami you out there?) but I thought I remembered they vary from front to back, which means you are not letting that JL 300/4 be all that it can be=). I tried searching around for the resistance values but had no luck.
-JustICE
Old Nov 24, 2004 | 01:29 AM
ChuckP's Avatar
no, the 6x9's are disconected, but thats not an isssue considering i can tap either set of lines for a signal. I do understand that there are different resistance rating for the bose speakers, and its only temp. untill i can afford some nice components and 6.5s for the quarters. But i got the 300/4 for 100 bones from some chick who didnt know anything, so why not put it to use u know? i know the bose paper woofers arnt all that, but it makes a big difference with a nice clean 4 chnl amp. So ima be doing this tomorrow night or thursday morn, as of now im going to tap my 6.5s in the rear, any objections? thx
Old Nov 24, 2004 | 02:57 PM
justICE's Avatar
Ah ok that sounds good. I believe the 300/4 has a low power output so that you can send a signal through your amp to the 500/1. Something similar to the following diagram.
-JustICE
Old Nov 24, 2004 | 03:01 PM
justICE's Avatar
pic
-JustICE
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
