Reality Check - Stereo Revamp
Old Oct 25, 2011 | 11:09 PM
AuAltima3.5's Avatar
I have an 05 coupe with bose. I think it sounds aweful.
What I really want is a clean, balanced system. I am looking for something that sounds great but I don't care for tons of bass, probably something small and sealed and I will try to make a box similar to the JL audio one (and not pay 500 for it )
My thoughts are either do just a DD HU and keep the bose, or do the whole system over like such:
  • DD HU & OEM DD Kit ~ 1000 (JVC KW-NT3HDT)
  • Mono Amp & (1) 8" sub ~ 350 (Alpine SWR-823D - unsure on amp)
  • Dual channel amp & comps for front ~ 400 (Want Focal Integration IS 130 cause they're Focals.. and no crossover box to mount - unsure on amp)
  • Misc Harnesses/Wiring ~ 200
I was pricing out stuff and it's looking like about 1800 for a revamp. With that said, is just a DD HU going to significantly impove the sound of the OEM speakers or is a complete overhaul in order? I will be installing FYI.
I was just kinda sticker shocked. I want to do it right, and if I go this route I can put it in another car, but jeez 1800 is steep. If anyone has suggestions on quality but affordable speakers/amps let me know. I'm kinda set on the HU but I don't know much in terms of speakers and amps. I don't want bargain basement, but don't need OCD Audiophile stuff.
Old Oct 26, 2011 | 07:07 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
That's a good headunit & the OEM kit is definitely the way to go if you care anything about looking right.
Have you looked into the boxology 10" box (the design that 4080 used for a while)? It sounds very good in my vehicle.
Focals up front is a good choice as well, soundstream reference series would probably be a good match, although they're not small amps, they're very clean SQ.
With a setup like that, you definitely should invest in sound deadening. My full recommendation goes to www.sounddeadenershowdown.com. Best advice and product available there.
Old Oct 26, 2011 | 06:02 PM
eggyhustles's Avatar
If u need small amps, soundstream stealth will do the job.
Old Oct 26, 2011 | 09:08 PM
Sounds like removing all the bose junk is the way to go, huh
A ten is bigger than I had wanted to get. My friend has a 10 in his M3, and I feel it's too much bass. I just want something better than 6x9s - something dedicated to bass.
I am no stranger to sound deadening. I did it to my altima, but man that was some **** to do. I didn't even touch the radio, I just did it for my OCD. It made talking on the cell bearable. I used spectrum sludge and raam mat. I saw second skin has a new "thick" damper mat that seems pretty nice.
....but I wasn't planning on doing the G. What areas would you recommend? I did the doors, trunk, and the rear half of the floor in my altima and was pretty happy. It totally removed the exhaust note which I wasn't so happy about. I don't want that happening in the G.
Are they reliable? Just worried about them dissapating heat properly if I mount them somewhere tight. I've also never heard of that brand (but I'm no audio guru either).
Old Oct 26, 2011 | 11:33 PM
Very reliable
I install A LOT of soundstream amps. They make the best budget and mid tier ones on the market.
Old Oct 27, 2011 | 12:26 PM
Major spots to deaden in the g are the trunk lid, doors and rear deck
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
NJ6MT
Sep 10, 2015 08:40 AM
