need opinions on my setup
Just wanted to get some opinion on the setup that I just bought, I've have been doing a lot of research on diamond audio and they seem to be my best bet from the reviews, I just bought the DA S600s for up front and bought thr DA M391i 6x9's for the rear deck, I bought the Phoenix Gold Ti600.2 to power the DA S600s I heard the speakers need lots of power so im gonna power the DA S600s at 150x2 @4ohms and I was think of running the rear 6x9's off the headunit for now. Would it be a bad choice to run the 6x9's off the head unit would they be getting enough power? I plan on getting a pair 6.5 midbass driver for the rear side panels and a four channel amp to run the 6.5 midbass drivers and the 6x9's in a couple of months. If you guys have any better suggestions on how I should set it up let me know. thanks
What a good midbass speaker I was thinking of getting a pair of kickers are they any good?
Sounds like you picked some good equipment. I hope you have actually listened to the Diamonds and they are what you want.
Are you replacing the factory HU? If so I would just run the 6x9 off the aftermarket head unit. If you're not replacing the factory HU just run them off the Bose amp. Are you going to be running a sub i the future?
For some reason when I first installed the new head unit the stock bose sounded pretty good but now there begining to sound like total ****. Did anone else notice that after they installed a aftermarket head unit
You should be ok running th 6x9s off the Pioneer HU, but I would run some type of high pass cross over on them. Have the crossover point set down around 50-60 hz, You'll lose whatever low end bass there was in the car, but will keep the 6x9 from getting killed.
