05 Sedan Factory Bose Question
Old May 15, 2012 | 04:17 PM
cmurphy84's Avatar
I have the factory Bose system in the car and I've noticed that it has very little bottom end until you hit volume 20. Then the bass kicks up a significant amount. When you turn it down, the bass remains at an increased level relative to the volume.
To get what I consider the best sound possible from the factory setup, I have to blast the system to 20, then drop it down to whatever level I want (typically between 8 and 12). What's up with that?
Old May 15, 2012 | 07:35 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Amp is probably starting to go, as it messes around a lot with the bass levels with the volume level.
Old May 16, 2012 | 05:29 PM
kei's Avatar
kei
There was an issue with the Bose system where the Bass/Treble settings get reset to the 0 position if you have any of the Bass/Treble settings to 5. You had to go into the settings and bring it down to 4 than back to 5 to bring it back to normal. I believe leaving it at 4 fixed this.
Old May 16, 2012 | 05:31 PM
cmurphy84's Avatar
Thanks for the info guys. I'll try it out when I leave the office.
Old May 23, 2012 | 08:18 AM
cmurphy84's Avatar
FYI - ^^ This fixed my problem. I set Bass at 4 and Treble at 3 and it sounds MUCH better.
Thank you!
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
kd03g99
Jul 30, 2015 11:24 AM
BlackGee35
Jul 21, 2015 07:24 PM
