Charging rate voltage ?
Old Jun 2, 2012 | 11:12 AM
tricky1's Avatar
At what voltage should my battery be charging at from the alternator ? reason i`m asking is because the 100 amp fuse on the fusiable link is trying to blow but not enough of something to blow it and the wire on the right side under the the 100 amp fuse is getting hot and starting to melt the wire and the connector that plugs into the fusiable link.
Detailed Image
Sep 28, 2015 07:04 AM
