FS: ST800 uninstalled from my G35 6MT - Parts
Old Aug 12, 2012 | 06:20 PM
rruotolo's Avatar
ST800 Items for sale, uninstalled from my G35 6MT
TWO LOTS of ST800 ITEMS
LOT #1 ($60, firm)
LOT #1 is a working ST800 remote…or at least it WAS working until the day the entire system started to flake. The remote comes with the leather case, as pictured. It is $60, firm. It sells for $100 new w/ case.
Here's a picture of the actual items included in LOT #1
NOTE: The remote was working until the entire system stopped working…so I’m assuming that the remote is fine.
NOTE: You will have to register the remote to your existing ST800 system. Instructions for how to do so are on-line. Search this forum for SSSMASSS.
BUYER BEWARE! NO RETURNS. NO TECH SUPPORT. ALL SALES FINAL.
LOT #2 ($90, firm)
LOT #2 consists of pieces and parts from the same ST800 that stopped working and was uninstalled.
LOT #2 includes all items in the picture here.
  • ST800 brain
  • ST800 keysense antenna and DOWONTEC bypass module with harness
  • ST800 window keypad, harness, and un-used kepypad sticker
  • ST800 siren
  • ST800 shock sensor with harness
  • ST800, ST800 push-to-start button with harness and two (2) trim rings
  • ST800 LF module* with harness
  • ST800 wand antenna with harness*
* NOTE: ST800 LF Module (aka “Smart Antenna”) AND ST800 wand antenna and harness have been modded/repaired, and may or may not still work. See picture or PM me for more details.
NOT INCLUDED IN LOT #2 are all ST800 harnesses (other than those pictured below/described above), AND any other ST800 items not described or pictured.
NOTE: All of these ST800 parts might be fine…OR SOME MIGHT BE HOSED. I have no way of knowing. The system was working one day…and the next day it started to flake, big time…most likely due to a bad connection.
NOTE: The ST800 brain is “un-cut” for a manual transmission install.
NOTE: The ST800 brain is missing the access cover, but this has no impact on function.
NOTE: In the process of uninstalling it, some less-than-optimal splices were discovered…done by a third-party installer who was clearly in a rush. These sloppy splices/taps MAY have been the reason the unit started acting up….but AGAIN…I have no way of knowing if the install was the problem…and COULD HAVE BEEN SALVAGED…or (IF AS A RESULT OF THE HALF-ASSED INSTALL), some ST800 components are actually damaged, and no longer useful.
Paypal payments add 3%. Postal Money Orders preferred.
Old Aug 21, 2012 | 02:13 AM
Tacoman22's Avatar
interested in lot 2 mine just started acting up as well ie proximity sensor no longer works
Old May 20, 2013 | 10:42 PM
sl00671's Avatar
St-800 remote
If you still have the remote, I will buy it from you. Send me an invoice request through paypal. My email address is sam_ly89@hotmail.com
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
