Driver side window wont go up!
hopefully this is the right place to post this
i was driving with the windows down and when i got close to home i tried putting it back up but it wouldnt go... the passenger side window was able to go up but the driver one wouldn't. Tried starting and re-starting the car but no luck. The window is all the way down so i cant see it.
any tips on what i can do? how much will this cost me?
its a 2004 g35 coupe btw
thanks
thanks
I looked it up and dont think ill be able to do it. Do you know approx. how much a garage would charge or should i take it to the dealer?
It should be your window motor. I had to replace both sides and about to do the driver's side again. If u slam the door while holding up the window switch it should go up for u. Quick fix but you will need to replace the motor.
So you think i should hold the window button while slamming the door and it should work?
how much will it cost to replace the motor and fix this problem?
thanks guys
Hopefully u tried this and it worked by now....the motor isn't expensive. U can get a reman at Advanced and get credit for your old one. I think it was around $100. I did that and it worked for a about a year and now I have to get another. Check craigslist. I found a guy selling the same reman's for $50! I do all the work myself, pretty easy to do bro...
vstypicals
Jul 20, 2015 10:55 PM
