X-Box mod for '05 coupe
Old Jan 21, 2005 | 08:42 AM
JohnnyHotrod's Avatar
Question X-Box mod for '05 coupe
Hello Everyone,
I'm going to do the X-Box mod using the Navbox with the PAC AAI-NIS for audio. My question is: Does anyone know if there is any difference in the '05 wiring? I don't have the satellite radio option but the headunit I have has a button that reads 'PTY-CAT' and not 'SAT' .
Thanks!
Old Jan 21, 2005 | 10:05 AM
symalik's Avatar
yea same here, i need to know but im pretty sure that is an AUX input. i still gotta order my navbox and the pac unit. keep us updated if u get anything new!
Old Jan 21, 2005 | 01:23 PM
garfieldthecat80's Avatar
yes the wiring is different for the 05. i took my G in to install a dvd player with my stock nav and they had problems. screen kept having wavey lines. installer tried everything. they used all sorts of stuff. they used the pac audio unit also. so far nothing has worked. if you find something that works, let us know.
Old Jan 21, 2005 | 03:40 PM
g8tor20's Avatar
FGC's official flip flopper
This sucks
Old Jan 21, 2005 | 04:02 PM
symalik's Avatar
this is sad, i shall put my engineering skills to work when the weather gets nice out here and if i can find a wiring diagram for the 05's. let me know if any one can help with that.
Old Jan 25, 2005 | 06:13 PM
Looking for an alternative to the PAC AAI-NIS audio interface
Looking for an alternative to the PAC AAI-NIS audio interface.OK...I found out that PTY/CAT button stands for PROGRAM TYPE and CATAGORY. This button is used to assign tags to FM radio stations. Since the PAC AAI-NIS audio interface uses the SAT button to choose auxillary inputs (the '05 coupe doesn't have a SAT button) I'll have to find another way to switch the audio input from the xbox.
I'd appreciate if anyone can help me with this.
Old Jan 25, 2005 | 06:41 PM
symalik's Avatar
yea tryin to figure it out, options dont look to good though
Old Jan 25, 2005 | 11:19 PM
g8tor20's Avatar
If I remember right, our manual says "SAT/RADIO" button. Does that mean the "radio" button will have a aux input? Sheer hope on my part.
Old Jan 26, 2005 | 01:17 AM
G-Thang's Avatar
I just successfully installed the PAC AAI-NIS in my '05 Coupe w/ Bose and Nav. PAC said they haven't tested on an '05 yet with the new head unit. I told them I'd let them know if it worked which it does **phew**. I'm actually using it with the XM Roady2 and considering the Xbox install too. I use a modded Xbox at home and love it. On the '05 the Radio button switches from AM, FM1, FM2, S1, S2 and seems to work fine so far.
Old Jan 26, 2005 | 09:51 AM
symalik's Avatar
i love you g thang
thanks for trying it out
i was gonna give up on the pac idea and just add a switch on my aftermarket amp to switch between the xbox and car sound. but since pac works dont have to worry about that
how was the dash disassembly?
Old Jan 26, 2005 | 08:09 PM
TrueG's Avatar
So you still haven't found a fix for it?
Did you use the Navbox? This is an important thread for me since I have the cash ready for a modded Xbox but this thing with the SAT button is killin me!!!!
So from a later stated post, if we press the radio button several times, we eventually get the SAT mode ergo the SAT wire harness?!
HELP!
Old Jan 26, 2005 | 08:39 PM
I was on the phone with PAC this morning and they assured me that their unit WILL work on '05. The thing is that when I press the Radio button all I get is AM, FM1, FM2, and CD. I'm hoping that when I plug the PAC unit into the back of the radio then SAT1 and SAT2 will appear.
Old Jan 26, 2005 | 10:17 PM
g8tor20's Avatar
I am also concerned with line noise on the Nav Screen. Some '05 owner had this problem and the shop couldn't figure it out.
Old Jan 27, 2005 | 11:34 AM
symalik's Avatar
thats just your grounding, 04 ad 03 people have had the same problem, there were previous threads on it. i forgot but i think it was just a grounding issue.
Old Jan 27, 2005 | 11:46 AM
g8tor20's Avatar
I thought the poster said that is wasnt the grounding nor the power inverter that was being used. Though I still figured it had to be simple (and correctable) line noise.
Though this is an X-box thread, has anyone with an 05 accomplished this with a AV Electronic box?
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
