Sirius ready?
Sirius ready?
I got the car a few years back, its a 2004 6MT. It has the antenna mounted under the hood, aside from that i have no idea if its all good to go. will I need one of the sirius radio units? Or can it run through the factory stereo?
my 05 is sirius ready. Not sure about 04. All I had to do was call Sirius and give them my radio id and it was allset. Keep hitting "Radio" until you see SR1 and it should give you a phone number to call.
Antenna mounted under the hood? As far as I know, that's not where they've ever put a satellite radio antenna. They've always been just above the rear windshield.
If you're factory wired for satellite, you'll have a harness in the trunk (exact location varies by year), and all you'd need to do is buy the antenna and satellite adapter from a dealer (Grubbs Infiniti has everything you need) to get it to work.
thanks guys, its pre wired, apparently the last owner set it up, he is the reason the antenna is mounted under the hood, all i need to do is find the tuner somewhere! local infiniti told me they wont bring it in for me.
Grubb's Infiniti definitely will hook you up with the adapter.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
