Key Fob Issues
Old May 26, 2013 | 01:23 AM
MrMobley's Avatar
Angry Key Fob Issues
Alright the other day my key fob stopped working, assumed it was the battery and replaced. No change, so then I tried programming it just in case that was the problem. Wouldn't program, could never get the second flash out of it to confirm programming. So I ordered a new fob, same issue. New battery in the new fob, go through the steps to program, get first flash of hazards, try to use fob to program and the car won't respond. Either the normal process does not work for my car, or there's some transmitter/receiver not working, or some fuse blown that I couldn't find(checked all fuses individually). Has anyone had a similar issue with not being able to get the second flash confirming programming? I have also checked my new fob to make sure it is the correct one. I'm at a loss now, all my searches are coming up empty for this issue. Hopefully someone out there has the answer.
Old Jun 14, 2013 | 09:32 AM
04g35mt's Avatar
i have the same issue, sub for a solution
Old Jun 14, 2013 | 09:38 AM
MrMobley's Avatar
Brought it in to the dealer and they said it was either the BCM or the wireless receiver (if there even is one) they didn't want to spill the beans. Said the fobs were both functional but the BCM was never receiving their signal. So it's a guess at this point on which part to change first.
Old Jun 14, 2013 | 10:36 AM
04g35mt's Avatar
hmmm, i wonder what the cost of the bcm will be, i'm sure itll be high from the dealer, mine seems to work when it wants, but mostly it doesnt. like you i changed batteries and even used the fob tester thing at autozone, says its working but usually doesnt
Old Jun 14, 2013 | 10:43 AM
MrMobley's Avatar
They run $100-200 used and shipped. I just don't want to drop that on the wrong part
Old Jun 14, 2013 | 10:47 AM
04g35mt's Avatar
oh that's not too bad, I understand not wanting to spend on the wrong part though, if you figure it out, let me know, ill look into it as well, maybe I can find one at the junkyard and try it out , see if it fixes the problem
Old Jun 14, 2013 | 10:51 AM
MrMobley's Avatar
Alright, sounds good. I'll keep this up to date on the results.
chinee
Jun 10, 2024 07:48 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
zcherub
Aug 30, 2015 05:04 PM
JMSABO
Aug 4, 2015 11:58 AM
apintojr
Jul 23, 2015 10:52 AM
