Grounding system question
Old Nov 10, 2013 | 11:03 AM
Speedster's Avatar
Quick question about grounding everything with my DD install. When connecting all the ground wires together for everything, is it necessary to then ground it all to the chassis or will just connecting the black wires be enough since I assume the factory system had it grounded somehow to the chassis through the wiring harness anyway?
Old Nov 10, 2013 | 12:38 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Ground it to the chassis.
Old Nov 11, 2013 | 09:15 AM
Mustang5L5's Avatar
Whatever you decide, pick 1 ground.
Multiple grounds can lead to creating ground loops. One good solid ground is better than multiple grounds in which one path has lesser resistance than another.
Old Nov 11, 2013 | 11:08 AM
WhosUrBuddiee's Avatar
Always ground to chassis
Old Nov 12, 2013 | 11:21 PM
Speedster's Avatar
thanks guys, used the chassis
miata007
Aug 17, 2015 04:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
