modifying the 8" boss to a 10" opening?
Old Dec 9, 2013 | 05:00 PM
romeow98's Avatar
Question modifying the 8" boss to a 10" opening?
Hello everyone I'm new to the form, although I have looked and used a lot of ideas from this community
The reason for this question is to free up trunk space for our baby stuff now. stroller ect.
I have a 2003 G35 infiniti sedan, it had the boss audio system which has been replaced with the stuff below, with the stock 8" sub in the rear
I have a complete after market system composing of
JVC (KW-XR810) double din deck,
JL Audio C2-650 component front
JL Audio C2-650x coaxial
powered by a rockford P4004 400 Watt 50x4 rms amp
and dual JL Audio 10W1v3-4 @ 2ohms
powered by AL Audio JX500/1D - bridged running about 347-450 rms
I was wondering if anyone has customized the stock location of the 8" boss to accommodate a 10" sub or not? as i'm looking to use one of my 10's in this location to help free up trunk space
if so how hard was it?
i know one can use the spare wheel compartment to hold the sub... has anyone tried placing dual 10's in the spare tire compartment?
Old Dec 9, 2013 | 05:31 PM
romeow98's Avatar
my bad man, thanks for pointing me in the right direction
Old Dec 9, 2013 | 06:43 PM
Frankieg35's Avatar
No problem, good luck with your search.. If u are looking for a sub box and still need to use your trunk check out the 4080 boxes..
Old Dec 9, 2013 | 08:21 PM
lucasg123's Avatar
I mounted an aftermarket 8" punch sub in the stock place and because it was bolted directly to the car it ended up vibrating a lot more than i got with a regular sub box. you could still do it this is just my experience.
Old Dec 9, 2013 | 08:54 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I haven't seen it done yet, but in addition to expanding the hole, you'll want to attach a good-sized piece of MDF to attach at multiple points to the rear deck so it doesn't vibrate horribly.
Even then, you're asking a lot out of the rear deck to contain a well-powered 10" sub.
Old Dec 9, 2013 | 10:00 PM
romeow98's Avatar
so far from my searching and gathering info's about this... noone has put a 10" in the rear deck?
Old Dec 9, 2013 | 10:23 PM
Urbanengineer's Avatar
FYI...
https://g35driver.com/forums/audio-v...ubwoofers.html
This is with 6.5" mounted subs and people voice many sound quality issues. Placing the sub here you are also advertising what you aren't selling... if you catch my drift.
The 4080 Box is the best bet and its easy to sell when you part with the car.
Old Dec 9, 2013 | 11:11 PM
romeow98's Avatar
that's a good read thanks - starting to make more sense on why people dont want to mount any subs in there, and with the stock bose cover, i think the sub would hid just fine... granted i didn't have to remove the parts within the cabin
Old Dec 11, 2013 | 02:18 PM
eggyhustles's Avatar
Rear deck is too flimsy for subwoofers.
If you want to go IB, do it on a baffle behind the rear seat.
Old Dec 11, 2013 | 02:40 PM
romeow98's Avatar
thats not a bad idea... but again i'm trying to free up more space in the trunk for baby stuff like the stroller and what not ... as the g35 is now a family vehicle.. hehe
Old Dec 11, 2013 | 02:46 PM
You retain 99% of your trunk real estate
Old Dec 11, 2013 | 04:05 PM
Trunk before
/____}
Trunk after baffle.
//___}
Trunk after 4080
/___-}
Plus you have to mount the amp somewhere... Wrathernaut's rear deck is the coolest placement I have seen on a sedan so far.
Old Dec 11, 2013 | 04:06 PM
+ you can no longer lower down the seats with the baffle.
Old Dec 11, 2013 | 05:06 PM
Yeah, not being able to fold down the seat can be a con for most.
Old Dec 11, 2013 | 07:10 PM
Sedan seats don't lower anyway.
