12 Constant,Accessory, and Ground Colors
Old Feb 9, 2005 | 04:44 PM
Gmachine's Avatar
I want to wire my Terk XM commander into the G with the Pac AAI-NIS adapter but I need the wiring scheme so I can wire it to go on when the radio goes on. I need the 12V Constant, Accessory, and Ground. I am assuming they will be Yellow, Red, and Black, are they? Thanks
Old Feb 9, 2005 | 07:56 PM
KPierson's Avatar
No, they won't be. If it were me I would go under the drivers dashboard and grab 12VDC there along with an ignition source. You can grab a ground under there too. The wire colors will vary based on the year of car and if its a coupe/sedan. Find the harness that goes up to the key cylinder and all your wires will be there.
cmesidewayz
Sep 29, 2015 09:28 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
Feffman
SouthEast
Sep 5, 2015 06:26 AM
