Help/advise upgrading factory subwoofer 05 g35 sedan
Old Apr 12, 2014 | 04:40 PM
Ig350zI's Avatar
Car: 2005 G35x sedan w/ Bose stereo
Alright, so i'm already pretty satisfied with the factory bose system that comes with my car. I would really like the option to turn the system up every once and awhile and get some extra bass. It looks like the G comes with a rear mounted 6.5" subwoofer and a factory amp built in next to it. What I would really like to do it find another 6.5" 2ohm (or 4 ohm dual) subwoofer I can replace this with and replace the factory amp as well, I will probably build an carpet a custom box on the upper trunk as to inclose the factory subwoofer mount. priority #1 I want to stay as stock looking as possible so I am trying to keep the box as slim and hidden as possible. Im not looking for a sh*t-load of bass just an extra hit in the car when I rock out to my dub step.
Question: has anyone done anything like this? Any suggestions for speaker or amplifier to use? can I use the factory wiring with a new amplifier? Any information would be awesome before I begin.
Old Apr 12, 2014 | 06:06 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Ok, so trying to keep this short.
You need an amp that takes a differential-balanced signal. JL audio amps do this, as do very few others.
Don't bother building a box if you're trying to do something like that (unless you're very skilled at box design); rather just go with a woofer that works well in an infinite baffle setup. If you're attaching it directly to the rear deck, you'll need to reinforce the deck, it's too flimsy for any decently-powered woofer on it.
You absolutely cannot reuse the factory power wiring, but speaker wiring can be reused without issue.
So, a JL 8w3 in an infinite baffle setup, or a well-constructed ported box underneath the rear deck would be a pretty good way to go.
Old Apr 13, 2014 | 02:11 AM
Ig350zI's Avatar
That is exactly what I wanted to hear, thank you!
Hasanbaloch
Feb 29, 2024 08:45 PM
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Blakelyg35
Aug 15, 2015 12:12 PM
laksjd84
Jul 24, 2015 05:12 PM
