Pioneer AVH-4000NEX checklist of what I'll need for installation
Old Oct 16, 2014 | 12:16 AM
ScraggleRock's Avatar
Man, use the search field. Wrathernaut has gone out of his way to make a complete shopping list for any setup you plan on building. Its a little insulting that you ask everyone to retype this info. Google search "wrathernauts double din shopping list".
Old Oct 16, 2014 | 12:22 AM
fattyspecial's Avatar
Thank you for your helpful reply. I don't see the parking brake bypass on that list.
Old Oct 16, 2014 | 12:30 AM
Hmm..
Old Oct 17, 2014 | 04:53 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
That's because discussion of bypassing safety devices is not allowed on this board.
Old Nov 9, 2014 | 11:26 PM
Hmmmm got everything hooked up and it sounds fantastic (many thanks to Wrathernaut!!) but the faceplate won't open. It looks like there is 1mm of clearance at the top between the 95-7605A and the head unit and maybe 3mm at the bottom but when I press the eject button it just makes noises and gives up. I'm going to call crutchfield support tomorrow but has anyone else had this problem?
Old Nov 10, 2014 | 01:52 AM
JG_G35's Avatar
I also have this problem, my unit hits the trim whenever I try ejecting or tilting the screen. I tried fixing it but eventually gave up. I don't really use CDs or need to move the screen so I learned to live with it.
Old Nov 10, 2014 | 07:43 AM
Mr. Brooks's Avatar
How much was your installation
Old Apr 15, 2015 | 08:01 PM
G35fromPA's Avatar
Were you ever able to solve this issue? I just got an AVH-4100 NEX and I'm about to install and would like to retain the tilt and eject function if possible.
Old Apr 15, 2015 | 09:27 PM
You just have to sure the trim you use to fill the gap isn't in the way by setting it further back, away from the moving parts.. I've done a couple with motorized faces and haven't had an issue with tilt/eject.
Old Apr 15, 2015 | 09:49 PM
G35fromPA's Avatar
Thanks. Did you use the trim ring for those installs, and did you then have the unit sticking out a bit more from the dash?
I've been test-fitting with the JDM kit and it looks like the trim will need to be set pretty far back underneath the HU. I may just go with some poly foam black tape built up underneath the unit instead of trying to get the Scosche trim ring to fit. I also want the face to be relatively flush with the dash kit, so it's tricky. And I won't know how well the eject function works until I can power the unit. I guess I need to bench power the unit and see how it will fit before tackling the install.
Old Apr 16, 2015 | 10:32 PM
Mine isn't far back at all, I just ran a single strip of trim on the bottom side - the strip of black trim is the portion that has "2707" on it - and it's being held upside-down in these photos:
And here's how it looks installed (sorry, don't have many photos of the finished installed):
Old Apr 17, 2015 | 04:45 PM
G35fromPA's Avatar
Perfect, thanks! I cut a strip off of the trim ring and glued it to the bottom of the JDM kit per your picture and bench tested the HU eject feature and it works perfectly. I used black foam around the top and sides of the HU and those seem to look good too. Next step is the install. Hoping to get to that this weekend.
Thanks for all your help so far.
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
