Power cable for AMP
Old Feb 13, 2005 | 09:21 PM
][ron|2icE's Avatar
Power cable for AMP
Hey ya, just wanted to ask how you ran the power cable from the battery to the amp in your trunk. I got my stuff but need to install it. Thanks.
Old Feb 13, 2005 | 10:08 PM
R2 V35's Avatar
Do a search, I believe there is a thread about this topic :-)
Old Feb 14, 2005 | 12:25 AM
skaline's Avatar
There's a grommet behind the battery cover. This one is easier to get thru than the one mentioned in the double-din conversion guide.
Old Feb 14, 2005 | 02:17 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Hmmmm....I don't remember mentioning any amp wiring or grommet stuff in my DD DIY guide...did I?!?!?
doc
Old Feb 14, 2005 | 01:45 PM
][ron|2icE's Avatar
thanks, that grommet leads to the passenger side right? Thanks.
Old Feb 14, 2005 | 01:53 PM
nismoGcoupe's Avatar
yes becareful when removing it I broke the clips that hold it in place when trying to take it off.
Old Feb 14, 2005 | 02:03 PM
skaline's Avatar
doc
Sorry doc,
I remembered after I posted that the amps & wiring were in a different DIY. I printed out a bunch of DIY's at the same time when I did the conversion, so they were all mixed up in my head. Your's was right on the money
Wil
Old Feb 14, 2005 | 02:05 PM
skaline's Avatar
Yeah, it the passenger side. Wires come straight down into the cabin. Very easy!!!
Old Feb 14, 2005 | 02:08 PM
docron1's Avatar
Originally Posted by skaline
Sorry doc,
Wil
no prob, i was just trying to think if I did mention that.....its been so long since I wrote that up....lol
doc
Old Feb 16, 2005 | 10:52 PM
][ron|2icE's Avatar
Thanks ya, I got my system hooked up today. I just punctured a small slit on the grommet. It WAS ez. Thanks.
Old Feb 17, 2005 | 09:39 AM
RacerX's Avatar
On my car, rather than punch a hole, I unwrapped all the goopy tape and inserted the amp wire in the rubber sleeve. There was no need to damage the weather seal or grommet. A bit messy, but this is a spot that needs to be well sealed to prevent leaks in heavy rains. Given that you've already cut the grommet, you might want to add some silicon RTV to the cut point to make sure you don't get a leak.
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
zcherub
Sep 10, 2015 12:03 PM
