Aftermarket head unit is QUIET !
Old Aug 27, 2014 | 12:44 PM
Northern_kaos's Avatar
i replaced the the bose 6cd factory unit with an aftermarket deck, but now the sound is very quiet, i can barely hear it cranked up, starts becoming distorted.
looking for the least costly way to fix this, maybe add some watts ???
is there a plug n play amp without having rewire all the speakers ?
Old Aug 27, 2014 | 01:07 PM
Urbanengineer's Avatar
Originally Posted by Northern_kaos
i replaced the the bose 6cd factory unit with an aftermarket deck, but now the sound is very quiet, i can barely hear it cranked up, starts becoming distorted. looking for the least costly way to fix this, maybe add some watts ??? is there a plug n play amp without having rewire all the speakers ?
What Bose amp converter did you use?
Old Aug 28, 2014 | 11:10 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
It's probably quiet because you didn't follow the guide on this site when purchasing parts. It's a common problem when somebody thinks they know what they're doing (even plenty of custom audio shops have screwed it up) instead of research.
Any amp is going to need new power and ground wires, but just about any 4-channel amp can replace the bose amp by only powering the rear deck and front door speakers using the factory speaker wiring. Using a 6-channel amp to include the rear doors/sides isn't worth the added cost and much more limited amplifier selection. The factory speaker wiring is just fine, I'm running 150w to each of the front doors through it (and nothing to my rear doors).
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
twentyeggs
Sep 11, 2015 03:58 PM
gatorglaze
Sep 10, 2015 12:03 PM
