AVH-4000NEX install and a couple questions
Hey everyone, just a couple questions. First, could anyone that has installed the AVH-4000NEX in a 03 sedan tell me if the install was flush using the standard holes on the bracket or if you had to drill new ones? Second, when installing the ASWC-1 for the steering wheel controls, do you just use quick splice connectors to tap the M39 harness?
Appreciate the help, and Happy Thanksgiving!
Thanks!
Thanks for the input. I don't own and have never used a soldering iron, so I think I'll try the quick splicers. Also, on the first couple pages of the shopping list thread there is mention to needing to solder in resistors, but I don't see mention of it in the first post. Was this just the way it used to be done?
Thanks!
Thanks!
Soldering irons are pretty cheap and you can practice on scraps of wire to get the method down.
Thanks!
rezendvous420
May 31, 2020 01:26 PM
