Help with wiring steering wheel controls
Old Dec 6, 2014 | 10:16 PM
Phileve11's Avatar
Hello all, installing this stereo http://www.pyleaudio.com/sku/PLDNV78...nd-Mexico-Maps
It's got built in steering wheel control. I just need to know which wire is the main steering wheel control wire. I uploaded a pic of the wiring diagram fir the radio.
Thanks
Attached Thumbnails Help with wiring steering wheel controls-20141206_140200.jpg
Old Dec 7, 2014 | 01:23 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's two signal wires from the car, and your headunit only has one signal wire input. From the amazon and sonicelectronix reviews, nobody's figured it out:
http://www.amazon.com/review/R2IC4WXWO4PE3V, http://www.sonicelectronix.com/i4373...t-Reviews.html
But, I'd guess that if you used a resistor on the wires (the way the PAC SWI unit differentiates the two wires into one) it'll work fine.
Connect the yellow wire from the vehicle's harness pictured below to the Pyle's SW KEY GND (gray) wire, the green wire connects to Pyle's SW KEY (green) wire through a 150 ohm resistor, and the red wire also connects to the Pyle's SW KEY (green) wire without a resistor.
jsimonk
Dec 22, 2023 03:49 PM
Gip
Aug 24, 2015 05:31 PM
kd03g99
Jul 30, 2015 11:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
