FS: Rare Polk SR6500 2 sets
Old Apr 8, 2015 | 07:33 PM
itpro2002's Avatar
2 sets of Polk SR6500 . . These are hands down the best sounding speakers I have ever heard . They will not fit my new ride 335i so I need to part with them. My lose your gain at 400.00 per set with all manuals and mounting hardware just like new !! Specs are below
ated Polypropylene (APP) Cone: The Polk Audio SR6500's woofers are constructed of Aerated Polypropylene, a mineral-filled polypropylene that has been "puffed up" with injected air to form a honeycomb-like structure. The result is a stiff, lightweight material with excellent damping qualities.
Surround: The cone is bonded to the basket with a soft butyl rubber surround. The injection-molded butyl rubber is tuned to absorb unwanted cone resonance. In addition, the surround is resistant to ultraviolet rays, temperature extremes, and humidity to add to the speaker's reliability and longevity.
Phase Plug: The bullet-shaped phase plug in the center of the driver ensures a smooth, flat, off-axis frequency response by preventing the high frequency sound waves emanating from one side of the cone from interfering with sound waves from the other side of the cone. The phase plug can be removed to convert the SR6500 into a coaxial speaker.
Basket: The woofer features a high-mass cast aluminum basket. The basket and magnet cover are one piece with heat sink fins that draw heat away from the voice coil, increasing power handling and reliability.
Voice Coil: The voice coil is wound around a 1-1/2" diameter low-mass, high temperature Polyimide-glass former. The large diameter coil contributes to the high bass output and high power handling of the driver.
Neodymium Magnets: The speaker uses a Neodymium magnet, which has the same magnetic flux power as a ceramic magnet 10 times its size.
Mounting Rings: Each woofer is equipped with two mounting rings which can reduce the mounting depth by as much as 3/4" when used together.
6" x 9" Adapter Rings: The woofers can be mounted in a 6" x 9" opening when used with the supplied adapter rings.
Tweeter Features
Ring Radiator Tweeter: The SR6500 has a 22mm (0.866") Ring Radiator tweeter, the same type as used in high-end audiophile home speakers. The Ring Radiator's ultra-light woven diaphragm is supported at two pivot points, with the voice coil attached approximately midway between the two pivots. Since there is a very small diaphragm area that is unsupported, there is less opportunity for the development of performance-robbing resonance. The phase plug, similar to the one found on the woofer, prevents phase cancellations, so you get a flat, smooth frequency response, both on- and off-axis.
Extended High Frequency Response: The tweeter's frequency response goes well beyond 20kHz: to 40kHz overall and to 30kHz at -3dB. This drives resonant peaks beyond audibility, and gives the speaker more overall detail and lower distortion levels.
Dual Neodymium Magnets: The tweeter has two Neodymium magnets to provide a powerful magnetic field for the voice coil, while still maintaining the tweeter's compact dimensions.
Faraday Cap: The motor structure includes a copper Faraday Cap on the pole piece to flatten the impedance curve, lower distortion, and extend and improve high frequency response.
Mounting Options: The tweeter can be mounted in a variety of ways. When the speakers are configured as separate components, the tweeter can be mounted in a straight flush-mount cup or in a 15° angled flush mount cup. In addition, you can remove the woofer's phase plug and mount the tweeter on the woofer as a coaxial speaker. Both straight and 15° angled tweeter posts are included with the system. When configured as coaxials, the tweeter speaker wire is threaded through the magnet and adds 3/16" to the mounting depth. The straight tweeter post adds a little over 1/2" (0.526") to the mounting height/tweeter protrusion, while the 15° angled tweeter post adds approximately 9/16".
Crossover Features
High Quality Components: The SR6500 crossover uses 1% tolerance resistors and capacitors to ensure the woofers and tweeters are perfectly matched to provide a solid, stable, and consistent stereo image. Air Core Inductors with Oxygen-free copper wire are used for wider dynamic range, contrast, and punch.
Zobel Network: The crossover includes a Zobel network, which flattens the system's impedance curve for a more efficient power transfer and flatter response.
Bi-Amping: The crossover's circuit board includes two jumpers which can be configured for single amplification or bi-amping. You can independently drive the woofer and tweeter with separate amplifier channels when the jumpers are removed. If driving the woofer and tweeter from the same channel, the jumpers should remain installed.
4-Position Tweeter Levels: You can adjust the output level of the tweeter at the crossover by positioning a jumper to one of four positions: -3dB, -1dB, 0dB, or +1dB.
Crossover Slopes: The crossover includes a 2nd order, 12dB per octave low pass filter for the woofer, and a 3rd order, 18dB per octave high pass filter for the tweeter. The crossover frequency for both the high-pass and low-pass filters is 3100 Hz.
Tweeter Protection: The crossover's Tweeter Protection device limits the current flowing into the tweeter, preventing damage to the tweeter when it is operated beyond safe operating levels.
Heat Sink: The crossover is housed in a heavy-duty solid cast aluminum chassis which acts as a heat sink for cooler operation and longer reliability.
Dimensions
Tweeters (mounted separately):
Straight Flush Mount 15° Angled Flush Mount
Mounting Height 0.395" (incl. grille) 0.812"
Depth 0.98" 0.511"
Frame Diameter 2.24" 2.37" Width, 2.33" Depth
Cutout Diameter 2.008" 1.191"
Crossover: The crossover dimensions are:
Width: 6.719"
Height: 1.573" (chassis) / 1.883" (overall, including *****)
Depth: 4.485"
Attached Thumbnails Rare Polk SR6500 2 sets-20150408_192023_resized.jpg   Rare Polk SR6500 2 sets-20150408_191841_resized.jpg   Rare Polk SR6500 2 sets-20150408_191803_resized.jpg
Old Apr 9, 2015 | 09:10 AM
itpro2002's Avatar
Feel free to make offers !!
Old Apr 13, 2015 | 01:14 PM
itpro2002's Avatar
Bump
Old Apr 16, 2015 | 08:45 PM
itpro2002's Avatar
Sold !!
mattdg35
Sep 14, 2015 11:28 AM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
