Full Custom Climate Control via Metra Board
So, I got a request from a new member here for a very custom build they're doing (Vaydor conversion), so there's a legitimate reason to do another FrankenMetra (tm) climate control. If you see their pictures of the metra in there, with nice leather all around, you'd agree to help prevent such a travesty too. In fact... here you go. This is what is being avoided:
http://vaydorexotics.com/wp-content/.../Interior2.jpg JUST SAY NO! This one will be going into a true custom dash, and will use Audi climate control buttons. As with the previous abomination, the rotary control for climate control will be the biggest issue, but there's always a way. Big lesson learned from the previous version is that re-using an existing circuit board leads to huge headaches from all the various circuit paths there are. So, this one is starting from a blank project breadboard. https://cimg7.ibsrv.net/gimg/g35driv...843e573a7b.jpg It will be cut down to rough size (slightly bigger, of course) with a rotary tool, then sanded down to a precise fit with some 100 grit sandpaper, and a file for the little corners. https://cimg1.ibsrv.net/gimg/g35driv...00476e831b.jpg Lined up and marked. https://cimg2.ibsrv.net/gimg/g35driv...6298d4d718.jpg Marked with the rough shape https://cimg3.ibsrv.net/gimg/g35driv...e19fca8869.jpg After the rotary tool cut, doing the precise sanding down. https://cimg4.ibsrv.net/gimg/g35driv...80c480a490.jpg Almost done! Another project board was cut down to fill the sides, since the board wasn't quite long enough to reach the defrost button positions. https://cimg9.ibsrv.net/gimg/g35driv...5228b4eda1.jpg Perfect fit! Now that the board is in place, the next step is to get the buttons in position. I got lucky with these, they have the exact same dimensions and feel as the factory pushbuttons, so I will not have to harvest anything from the Audi control board. https://cimg3.ibsrv.net/gimg/g35driv...ece75e051e.jpg With the buttons lined up, the first test of them is complete. Video will be viewable here once it's processed: I'm not sure if the LEDs will ever work, they're just SO TINY and don't like coming off at all. |
Part #2 - Wiring
The next piece arrived today - the 40-pin IDE extension cable.
I started by wiring up the common input wire for all the buttons to be used. https://cimg1.ibsrv.net/gimg/g35driv...302f51cb73.jpg Common wiring complete https://cimg4.ibsrv.net/gimg/g35driv...6682b0598a.jpg Wiring up the control wires. https://cimg5.ibsrv.net/gimg/g35driv...d0216ad556.jpg Control wiring complete. Lots of extra wires on the 40-pin harness. https://cimg6.ibsrv.net/gimg/g35driv...8918420d59.jpg Reassembled. https://cimg0.ibsrv.net/gimg/g35driv...2abe4ec8ca.jpg Reassembled with excess wires hanging out. https://cimg8.ibsrv.net/gimg/g35driv...12171c4052.jpg 40-pin harness with the other half of the extension. Now that it's back together, I've done testing of all the buttons through the wires. It's ready for the Metra board to connect to it. I'm leaving those excess wires from the harness for now. If the metra board sends the same voltage for LEDs, I might end up using them to illuminate the controls. |
Part 3.
Metra board arrived, and was promptly disassembled and put under the soldering pen. https://cimg4.ibsrv.net/gimg/g35driv...4ab455884f.jpg All the wires were marked according to function, since I don't have 14 different color wires of the right thickness to choose from https://cimg5.ibsrv.net/gimg/g35driv...f47ff7e6e1.jpg Once the wires were all soldered to the metra board, I ran them through some wire loom and soldered to the other half of the IDE extension cable through some super tiny heatshrink. I wish I'd put more of the large heatshrink on the loom before I started, since I'd much rather use that to bridge down to the smaller loom than the electrical tape. Either way, it worked out well. https://cimg6.ibsrv.net/gimg/g35driv...c5e232177f.jpg All the wiring is complete - and you can see something here that nearly had me pulling my hair out when it didn't work.<br/><br/>Give up? It's the missing jumper on the OPTION setting on the metra board, but luckily I remember this old post - https://g35driver.com/forums/audio-v...ller-read.html and put a jumper in the right spot. OPT 1 for 05-06, not sure if it's the same for 2003-2004.. https://cimg4.ibsrv.net/gimg/g35driv...d616db75ef.jpg Fully assembled and plugged in. https://cimg5.ibsrv.net/gimg/g35driv...f1a3e2f763.jpg ... and run all the way to the metra board, which does all the translating to the car. So, after a few hours of work, here's the horribly rough video, but it's late and I really don't feel like busting out the video editing software. |
7 Attachment(s)
Part 4:
The LEDs arrived, five colors to choose from, tested by just shoving LEDs in the holes behind the buttons. You can also see the light shining through the temp sensor vent here. That gets addressed later. Attachment 260295 Yes, red is the way to go. So, the full Audi part was too wide for this application, and there's the extra piece underneath. Good thing I've got a good compliment of saws at my disposal. Attachment 260296 That underhang goes first. Then the sides. Attachment 260297 Now, to plug the air temp sensor vent holes - the one on the right has a painstakingly custom piece of plastic filling it. Attachment 260298 And now it's time to mount the lights. One down! Attachment 260299 A whole mess of wiring later... Attachment 260300 Now it lights up via the illumination wires - whenever the backlighting is on on the metra slave board, it's on on the custom board too: Attachment 260301 Hopefully the next pictures of this thing are post-install in the Vaydor. So, lessons learned for the next time something like this comes up:
looks awesome so far! cant wait to see how it turns out!
thanks again!! |
Woah excellent work! Nice to hear you are still going crazy ha. I'm just learning about hardware modification myself.
That metra looks like *** in that super custom car. Why would you put that in a Vaydor car, let alone a G35. |
(Post 7085347)
You truly are gifted my friend. I like knowing my DD has been customized by you.
Originally Posted by Wrathernaut
(Post 7085284)
http://vaydorexotics.com/wp-content/.../Interior2.jpg JUST SAY NO! To the Vaydor conversion........ JMO though, I can't understand why someone would put all this work into a 10 year old plus G but if it's what the owner wants I certainly can't hate. As usual Wrather, your work is impressive and I'm more than a little jealous because I know diddly squat about electronics. I'm starting to research them though, I always want to get better at things I don't know about, which means I have a LOT to learn lol. :JAMIN: |
Originally Posted by dukehotty
(Post 7085520)
https://cimg8.ibsrv.net/gimg/g35driv...360d6e11ef.jpg https://cimg9.ibsrv.net/gimg/g35driv...6aee00ab9f.jpg |
(Post 7085532)
Fixed the first part of your post for you...........
Bump because part 3 is up.
nice job.
now get those leds working. shame the knob cant be utilized |
wow im seriously blown away there is no limit to your skills
whats the size lenth like audi board compaired to the metra ? :)
